Re: [petsc-dev] Open PRs to be merged for release 3.7
On Sun, 24 Apr 2016, Lisandro Dalcin wrote:
Satish, I have two open PRs ready to be merged into master (already merged into next). As you are in charge of making the release, I did not want to step on you, so I'll not make the merge into master until you acknowledge. Or just merge them yourself through the Bitbucket interface.
Lisandro,
Looks like I won't be able to merge then for 3.7.
If the API reviewers [Jed, Barry] says that API isn't changing - then I'll schedule them for 3.7.1. [If not - they can be 'master' features]
Barry agreed in petsc-dev ML to get these new features in. This is because of your premature update of 'maint' branch?
I was hoping for a feature freeze - by my maint branch merge. [and Barry agreed to that :). See the text of the post: "[petsc-dev] plans for PETSc release"] Irrespective the maint issue - the changes are not yet tested in next. Even if its tested in tonights next - they would be untested in maint/master. So I can't do both - merge them tomorrow and spin a tarball tomorrow.
PS: These two PRs are forward compatible: they add new APIs, but do not modify previous ones in any way.
Then there should be no problem with scheduling them for 3.7.1 one issue : does Jed consider changes to include/petsc/private/tsimpl.h as API/ABI change and object.. Satish
participants (1)
Satish Balay
