Re: [petsc-dev] buildsystem package dependencies
On 5 April 2011 13:29, Matthew Knepley <[email protected]> wrote:
On Tue, Apr 5, 2011 at 11:20 AM, Satish Balay <[email protected]> wrote:
Not sure I understand. If I say 'mpi depends on mpe' - then the link line is:
-lhypre -lmpi -lmpe
But thats incorrect usage - and not what I want.. The correct usage is: -lhypre -lmpe -lmpi
The issue comes up with -llmpe - which traps MPI_xx functions - and does some logging - and then calls MPI_xx functions from -lmpi. i.e usage is:
-lhypre -llmpe -lmpe -lmpi
Right, but this MPE package is changing the MPI interface. All those other packages, like Hypre, depend on MPI. MPI depends on MPE, but the MPE module may modify the MPI lib to be '-lmpe -lmpi'. I do not see another way to do this. Matt
We could also build a custom libmpe.so, load it at runtime from petscmpiexec by passing a -mpe flag. This way, we can get MPE logging for free, using a regular PETSc build. This is more or less described at the end of this ticket: https://trac.mcs.anl.gov/projects/mpich2/ticket/573. What do you think? -- Lisandro Dalcin --------------- CIMEC (INTEC/CONICET-UNL) Predio CONICET-Santa Fe Colectora RN 168 Km 472, Paraje El Pozo 3000 Santa Fe, Argentina Tel: +54-342-4511594 (ext 1011) Tel/Fax: +54-342-4511169
participants (1)
Lisandro Dalcin
