Re: [petsc-dev] MUMPS and 64 bit indices
On Dec 15, 2014, at 5:57 PM, Matthew Knepley <[email protected]> wrote:
On Mon, Dec 15, 2014 at 4:17 PM, Barry Smith <[email protected]> wrote:
I cannot fix this. There is a cycle in the dependencies if I introduce libraryOptions inside package.py so package.py cannot do the consistency check, but it should so it is totally screwed.
Matt could fix it but he'd probably have to fuck up the nice simplicity of the code that is there now :-(!
We were already using a mechanism to get around this circularity. Comments on the aesthetic import welcome.
I think the trauma of seeing the provides interface destroyed part of my brain years ago, hence I didn't realize it could be used here. So, yah, if this works its fine and the way to go. Thanks Barry
https://bitbucket.org/petsc/petsc/branch/knepley/fix-configure-package-check
Matt
Barry
On Dec 15, 2014, at 3:42 PM, Barry Smith <[email protected]> wrote:
On Dec 15, 2014, at 3:16 PM, Garth N. Wells <[email protected]> wrote:
It's possible to configure PETSc with the options
--with-64-bit-indices --download-mumps
and compile and run, but it doesn't look like the MUMPS interface supports 64 bit indices. Should the above combination throw an error at configure time?
Yes, there is commented code in the consistency check, I cannot remember why it was commented.
# if self.double and not self.scalartypes.precision.lower() == 'double': # raise RuntimeError('Cannot use '+self.name+' withOUT double precision numbers, it is not coded for this capability') # if not self.complex and self.scalartypes.scalartype.lower() == 'complex': # raise RuntimeError('Cannot use '+self.name+' with complex numbers it is not coded for this capability') # if self.libraryOptions.integerSize == 64 and self.requires32bitint: # raise RuntimeError('Cannot use '+self.name+' with 64 bit integers, it is not coded for this capability')
(On a side note, SuperLU_dist and Umfpack are flaky with 64 bit indices, which seems largely related to calling ParMETIS/METIS).
Hmm, never heard such reports. Are you using the --download-parmetis and metis? You should be. Is it reproducible problem? We'd like to fix it.
Barry
Garth
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Barry Smith
