I made this change because synchronized printing was cutting off my stuff. Now the queue is dynamically allocated so it can accomodate any size string. I tried ex7 and it runs fine for me, even under valgrind. Shi, can you reproduce this with a Sieve example? Matt On Mon, Jul 21, 2008 at 2:37 PM, Satish Balay <[email protected]> wrote:
Looks like this could be related to changeset 9e3fbe04a926
--> mprint.h <--
- char string[QUEUESTRINGSIZE]; + char *string;
So now strings needs to use malloc()/free()?
Matt - you can reproduce this issue with dm/ao/examples/tests/ex7.c
Satish
On Mon, 21 Jul 2008, Satish Balay wrote:
---------- Forwarded message ---------- Date: Sun, 20 Jul 2008 22:39:13 -0700 (PDT) From: Shi Jin <[email protected]> Subject: problem with PetscSynchronizedFPrintf To: [email protected]
I recently updated my petsc-dev and found my previously working code is having trouble running in parallel. I've narrowed it down to the calls to PetscSynchronizedFPrintf. Even if I don't have those, I will have errors at the end of my MPI runs like: [1]PETSC ERROR: PetscMemzero() line 189 in src/sys/utils/memc.c [1]PETSC ERROR: PetscViewerASCIISynchronizedPrintf() line 859 in src/sys/viewer/impls/ascii/filev.c [1]PETSC ERROR: PetscMemoryShowUsage() line 367 in src/sys/memory/mtr.c [1]PETSC ERROR: PetscFinalize() line 675 in src/sys/objects/pinit.c [1]PETSC ERROR: completeSection() line 163 in main.cxx [0]0:Return code = 0, signaled with Interrupt [0]1:Return code = 85
Since the same code was running fine before the update. I am wondering if it is something recently introduced. Thanks a lot.
-- Shi Jin, PhD
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Matthew Knepley
