mpi_comm_create_group()
hi This question is not strictly PETSc-related but I figure you guys are probably most likely to know the answer. I need to do some simple computations involving only a small subset of the parallel processes in my simulation. From reading the MPI documentation and a few tutorials it looks like mpi_comm_create_group() is probably the thing to use for creating the MPI communicator in this case. Since there are only a few processes in the group, from what I can gather this function should be more efficient than mpi_comm_create(), as it's only collective on the group, not the whole parent communicator (MPI_COMM_WORLD). 1) Is it correct that mpi_comm_create_group() should be a better option in this case than mpi_comm_create()? I had a grep through the PETSc source code and there are some calls to mpi_comm_create() but none to mpi_comm_create_group(). But maybe the use case is different. 2) If mpi_comm_create_group() is the better option, is it necessary to call it on all processes, or only the ones in the group? The tutorial at https://mpitutorial.com/tutorials/introduction-to-groups-and-communicators/ calls it on all processes, but other stuff I've read suggests you only need to call it on processes in the group. It seems to work either way, but you have to use the communicator a little differently. - Adrian -- Dr Adrian Croucher Senior Research Fellow Department of Engineering Science University of Auckland, New Zealand email: [email protected] tel: +64 (0)9 923 4611
participants (1)
Adrian Croucher
