Re: [petsc-dev] release preparation
I've now created the release repos - so petsc-dev is now open for all commits. [If you've accumulated petsc-dev related commits - rebasing them with current petsc-dev - before pushing would be good.] Release related commits should now go to the release repo [and not directly to petsc-dev]. Please use the usual release repo workflow. i.e: - clone the release repos - commit/push [to release-repos] - from petsc-dev clone - pull/merge release commits and push to petsc-dev. [or defer this last step to me until the release] ssh://[email protected]//hg/petsc/releases/petsc-3.3 ssh://[email protected]//hg/petsc/releases/BuildSystem-3.3 Satish On Thu, 17 May 2012, Barry Smith wrote:
petsc-dev folks,
Recall that we are in a phase of a code freeze that means do not push random new code to petsc-dev, push only bug fixes and clean up to petsc-dev. By all means keep on with code development, just don't push the new stuff to petsc-dev.
We hope to make the release repository (and then tarball) next Wednesday May 23. So please do be checking the nightly builds and making fixes to petsc-dev.
Barry
Note: threaded code and GPU code will not be supported with the release (users should continue to use petsc-dev after the release) so fixes/extensions to those things are not needed and shouldn't be pushed to petsc-dev at the moment.
participants (1)
Satish Balay
