Re: [petsc-dev] Recommended Petsc Build Procedure
22 Apr
22 Apr
'12
9:46 a.m.
I use the CMake build because it's the fastest, though it requires you to have CMake installed on your system. A On Sun, Apr 22, 2012 at 5:42 PM, Dave Nystrom <[email protected]
wrote:
At the end of configure.log, there are two possible ways to build petsc-dev that are specified. Which is the recommended way to build - using make or using python? I have been using make.
Also, one is labeled as legacy and one is labeled as experimental. That gives the impression of having a choice between an old, archaic method or a new, experimental approach. Should one just be labeled as production?
Dave
5226
Age (days ago)
5226
Last active (days ago)
0 comments
1 participants
participants (1)
Aron Ahmadia
