Re: [petsc-dev] Reminder: *every* symbol with extern linkage *must* be namespaced
On Mon, 19 Mar 2012, Matthew Knepley wrote:
On Mon, Mar 19, 2012 at 10:03 AM, Jed Brown <[email protected]> wrote:
2012/3/19 Satish Balay <[email protected]>
The other issue here is: multiple library conflict. If there is a user using tetgen directly [and has a separate install of it] - and also uses petsc from the same code , then there could be duplicate symbol issue. [Now the solution is - don't link with a separate tegen - just link with petsc - but thats generally not good.]
Matt has significantly modified tetgen (removing its superfluous use of C++) so all these symbols are different.
AND you could have tested your assumption of a problem by trying it with --download-tetgen, which
From the emails it wasn't obvious that you are planning on a new name 'ctetgen' - all references were to tetgen.
works because this is how I tested it. The --download-ctetgen option will work shortly.
What is this with criticizing what I do before even finding out what I actually did?
sorry - I misunderstood the situation based on this email thread.. The reason I resopinded to the license issue is - we do get emails from folks who are concerend and want clarificaton regarind petsc usage and license. satish
participants (1)
Satish Balay
