PCASM uses DMCreateDecomposition which splits field, NOT expected behavior
On Saturday, May 26, 2012, Jed Brown <[email protected]> wrote:
Dmitry, I have problems with this commit. http://petsc.cs.iit.edu/petsc/petsc-dev/rev/440ec9350d51
If I try running -pc_type asm with a vector problem defined on a DM, PCASM calls DMCreateDecomposition which splits fields on each process. This is of very limited value since usually every field is coupled to every other, so after increasing the overlap by one, you end up solving the entire subdomain twice. However, at this point, you are not using overlap so instead, we get subdomain and field blocked Jacobi. (Equivalent to BJacobi with additive fieldsplit inside.) This is certainly unexpected behavior. It also crashes with Seq(S)BAIJ because MatGetSubMatrices_SeqBAIJ can only extract when the block size matches. And it does the wrong thing when used with MPI(S)BAIJ because MatGetSubMatrices_MPIBAIJ calls ISCompressIndicesGeneral which silently "fills in" the blocks, leading to a Mat and Vec size mismatch. Hong, how should we enforce that the original index set actually addresses blocks? Why is it not okay to sort? (Don't we rely on those indices being sorted somewhere else anyway?)
The problem is that this API mixes field splits and (spatial) domain decompositions. Initially I thought the two kinds could be served up via the same API because they use the same syntax, but the semantics are different. In particular, domain decompositions don't change the block size, while field splits typically do. Then it's usually downwards -- when splitting up a block of fields pointwise, but sometimes upwards -- in a primal-dual split of a KKT system the primal subsystem might have a higher natural block size than the full system. I think the solution is to split up the API: DMCreateFieldSplit() and DMCreateDomainDecomposition(). I'll look into it later tonight, when I get to my computer.
Our test coverage must be pretty sucky if we went two months with ASM this broken for systems.
As a lower priority, -pc_asm_decomposition should provide a list of valid decompositions rather than be a magic string. Also, this form cannot be called outside of a PetscOptionsBegin/End pair, otherwise it doesn't print -help output. It should be moved to PCSetUp_ASM. ierr = PetscOptionsString("-pc_asm_decomposition", "Name of the DM defining the composition", "PCSetDM", ddm_name, ddm_name,1024,&flg); CHKERRQ(ierr);
The problem here is that the PC object doesn't really know what decompositions are available -- the DM does. We could have DMGetSubdomainDecompositionNames() advertise what'd available. Another problem is that what decompositions make sense is DM-impl-dependent. It is more stark for fieldsplits: I have a fork of libMesh that can generate decompositions based on the system's variables, and essentially any groupings of variable names are valid splits ( e.g., v1,v2;v3,v4. I think it makes sense to maintain that flexibility). Because of that I think the best help line would only exhibit the syntax, rather than enumerate all possible splits. Then DMSetUp_Xxx should handle that. Dmitry.
I have disabled that code for now, but we have to decide whether it's
conceptually right (considering the effect on overlap) and if so, how to fix it.
participants (1)
Dmitry Karpeev
