Seeking Advice on Petsc Preconditioners to Try
I have a linear system in a code that I have interfaced to petsc that is taking about 80 percent of the run time per timestep. This linear system is a symmetric block banded matrix where the blocks are 2x2. The matrix looks as follows: 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1X X Y Y Y 2X X X Y Y Y 3 X X X Y Y Y 4 X X X Y Y Y 5 X X X Y Y Y 6 X X X Y Y Y 7 X X X Y Y Y 8 X X X Y Y Y 9 X X X Y Y Y 0 X X X Y Y Y 1 X X X Y Y Y 2 X X X Y Y Y 3Z X X X Y Y Y 4Z Z X X X Y Y Y 5Z Z Z X X X Y Y Y 6 Z Z Z X X X Y Y Y 7 Z Z Z X X X Y Y Y 8 Z Z Z X X X Y Y Y 9 Z Z Z X X X Y Y Y 0 Z Z Z X X X Y Y Y So in my diagram above, X, Y and Z are 2x2 blocks. The symmetry of the matrix requires that X_ij = transpose(X_ji) and Y_ij = transpose(Z_ji). So far, I have just input this matrix to petsc without indicating that it was block banded with 2x2 blocks. I have also not told petsc that the matrix is symmetric. And I have allowed petsc to decide the best way to store the matrix. I can solve this linear system over the course of a run using -ksp_type preonly -pc_type lu. But that will not scale very well to larger problems that I want to solve. I can also solve this system over the course of a run using -ksp_type cg -pc_type jacobi -vec_type cusp -mat_type aijcusp. However, over the course of a run, the iteration count ranges from 771 to 47300. I have also tried sacusp, ainvcusp, sacusppoly, ilu(k) and icc(k) with k=0. The sacusppoly preconditioner fails because of a thrust error related to an invalid device pointer, if I am remembering correctly. I reported this problem to petsc-maint a while back and have also reported it for the cusp bugtracker. But it does not appear that anyone has really looked into the bug. For the other preconditioners of sacusp, ilu(k) and icc(k), they do not result in convergence to a solution and the runs fail. I'm wondering if there are suggestions of other preconditioners in petsc that I should try. The only third party package that I have tried is the txpetscgpu package. I have not tried hypre or any of the multigrid preconditioners yet. I'm not sure how difficult it is to try those packages. Anyway, so far I have not found a preconditioner available in petsc that provides a robust solution to this problem and would be interested in any suggestions that anyone might have of things to try. I'd be happy to provide additional info and am planning on packaging up a couple of examples of the matrix and rhs for people I am interacting with at Tech-X and EMPhotonics. So I'd be happy to provide the matrix examples for this forum as well if anyone wants a copy. Thanks, Dave -- Dave Nystrom phone: 505-661-9943 (home office) 505-662-6893 (home) skype: dave.nystrom76 email: [email protected] smail: 219 Loma del Escolar Los Alamos, NM 87544
participants (1)
Dave Nystrom
