Re: [petsc-dev] MatMatMult gives different results
On Thu, Feb 9, 2012 at 08:30, Matthew Knepley <[email protected]> wrote:
On Thu, Feb 9, 2012 at 2:48 AM, Alexander Grayver <[email protected]
wrote:
** lib/petsc-dev> hg pull -u pulling from http://petsc.cs.iit.edu/petsc/petsc-dev searching for changes no changes found
Does it take some time till it's there?
You have to remake Fortran stubs: make allfortranstubs
and then make.
So we have some confusion right now because Matt is pushing to bitbucket first and Barry is pushing to petsc.cs.iit.edu. I would be happy to experiment with using bitbucket as the primary for petsc-dev and have petsc.cs.iit.edu be the mirror (so users can keep tracking petsc-dev without changing URLs). The simple convenience of having https:// and ssh:// trivially push/pull the same repository is enough to make me prefer interacting with bitbucket (screwy networks filter ssh). But "two-way mirror" does not work, so we have to agree about where we are pushing.
participants (1)
Jed Brown
