On Sat, Feb 18, 2012 at 10:18 PM, Satish Balay <[email protected]> wrote:
On Sat, 18 Feb 2012, Barry Smith wrote:
2) If the rebase implementation has been fixed from the hacky versions that fucked unnecessarily with my file system I'll be happy to start using rebase. Is it fixed?
The issue is:
When file 'a.c' is locally commited, and a pull potentially has changes to 'b.c', 'pull --rebase' also changes the timestamp on a.c [whereas 'pull; merge; commit' does not change timestamp on a.c] <<
Latest hg [version 2.1] still updates the timestamp of a.c on rebase.
Rebase is doing state changes [wrt commit states] - in this process I think removes local changesets and recommits them - so the locally changed files get new timestamps in this process.
The fact that 'make' relies on timestamps messes things up [causing unnecessary recompiles]. Reseting timestamps on unchanged files would be a good optimziation - which is what Barry wants..
Ah, I don't see it because the Python build uses md5. Doesn't cmake? Matt
Satish
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Matthew Knepley
