Re: [PETSC #16801] petsc-dev make test breaks with 2 processes?
I pushed a fix. Matt On 9/26/07, Matthew Knepley <[email protected]> wrote:
Cool, I can reproduce the failure. Satish just put code in to check this, so the error makes sense. I will find it after my run.
Matt
On 9/25/07, mspieg <[email protected]> wrote:
Hi all, I just pulled, reconfigured and rebuilt petsc-dev (changeset: 11135:7c2e5fab809d) and the 2 processor test failed with an error from PetscLogFlops (see error message below). The same configuration file works fine in the the latest release 2.3.3-p6. Not immediately critical, but I need petsc-dev for the PCDMMGDM routines (of which I'm still tracking down a pernicous bug, but am getting close). All help greatly appreciated cheers marc p.s. system is MacOSX 10.4.10, mpich2-1.0.5p4
-------------output of make test---------------------- Running test examples to verify correct installation C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI process Possible error running C/C++ src/snes/examples/tutorials/ex19 with 2 MPI processes See http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html lid velocity = 0.0016, prandtl # = 1, grashof # = 1 [0]PETSC ERROR: --------------------- Error Message ------------------------------------ [0]PETSC ERROR: Argument out of range! [0]PETSC ERROR: PetscLogFlops: flop-count given is neagitive: -32.00! [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: Petsc Development Version 2.3.3, Patch 6, unknown HG revision: unknown [0]PETSC ERROR: See docs/changes/index.html for recent updates. [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting. [0]PETSC ERROR: See docs/index.html for manual pages. [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: ./ex19 on a macosx-gn named mingus.home by mspieg Tue Sep 25 23:34:58 2007 [0]PETSC ERROR: Libraries linked from /Applications/petsc/petsc-dev/lib [0]PETSC ERROR: Configure run at Tue Sep 25 23:12:21 2007 [0]PETSC ERROR: Configure options CC=gcc FC=gfortran --with-python --with-shared=1 --with-dynamic=1 --with-mpi-dir=/Applications/mpich/mpich2-1.0.5p4 --do [1]PETSC ERROR: --------------------- Error Message ------------------------------------ [1]PETSC ERROR: Argument out of range! [1]PETSC ERROR: PetscLogFlops: flop-count given is neagitive: -84.00! [1]PETSC ERROR: ------------------------------------------------------------------------ [1]PETSC ERROR: Petsc Development Version 2.3.3, Patch 6, unknown HG revision: unknown [1]PETSC ERROR: See docs/changes/index.html for recent updates. [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting. [1]PETSC ERROR: See docs/index.html for manual pages. [1]PETSC ERROR: ------------------------------------------------------------------------ [1]PETSC ERROR: ./ex19 on a macosx-gn named mingus.home by mspieg Tue Sep 25 23:34:58 2007 [1]PETSC ERROR: Libraries linked from /Applications/petsc/petsc-dev/lib [1]PETSC ERROR: Configure run at Tue Sep 25 23:12:21 2007 [1]PETSC ERROR: Configure options CC=gcc FC=gfortran --with-python --with-shared=1 --with-dynamic=1 --with-mpi-dir=/Applications/mpich/mpich2-1.0.5p4 --download-mpich-pm=gforker --with-debugging=1 PETSC_ARCH=macosx-gnu-local-g [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: MatMultAdd_SeqMAIJ_4() line 585 in src/mat/impls/maij/maij.c [0]PETSC ERROR: MatMult_MPIMAIJ_dof() line 2118 in src/mat/impls/maij/maij.c [0]PETSC ERROR: MatMult() line 1670 in src/mat/interface/matrix.c [0]PETSC ERROR: MatInterpolate() line 5925 in src/mat/interface/matrix.c [0]PETSC ERROR: PCMGFCycle_Private() line 28 in src/ksp/pc/impls/mg/fmg.c [0]PETSC ERROR: PCApply_MG() line 207 in src/ksp/pc/impls/mg/mg.c [0]PETSC ERROR: PCApply() line 356 in src/ksp/pc/interface/precon.c [0]PETSC ERROR: FGMREScycle() line 232 in src/ksp/ksp/impls/gmres/fgmres/fgmres.c [0]PETSC ERROR: KSPSolve_FGMRES() line 358 in src/ksp/ksp/impls/gmres/fgmres/fgmres.c [0]PETSC ERROR: KSPSolve() line 378 in src/ksp/ksp/interface/itfunc.c [0]PETSC ERROR: SNES_KSPSolve() line 2539 in src/snes/interface/snes.c [0]PETSC ERROR: SNESSolve_LS() line 184 in src/snes/wnload-mpich-pm=gforker --with-debugging=1 PETSC_ARCH=macosx-gnu-local-g [1]PETSC ERROR: ------------------------------------------------------------------------ [1]PETSC ERROR: MatMultAdd_SeqMAIJ_4() line 585 in src/mat/impls/maij/maij.c [1]PETSC ERROR: MatMult_MPIMAIJ_dof() line 2118 in src/mat/impls/maij/maij.c [1]PETSC ERROR: MatMult() line 1670 in src/mat/interface/matrix.c [1]PETSC ERROR: MatInterpolate() line 5925 in src/mat/interface/matrix.c [1]PETSC ERROR: PCMGFCycle_Private() line 28 in src/ksp/pc/impls/mg/fmg.c [1]PETSC ERROR: PCApply_MG() line 207 in src/ksp/pc/impls/mg/mg.c [1]PETSC ERROR: PCApply() line 356 in src/ksp/pc/interface/precon.c [1]PETSC ERROR: FGMREScycle() line 232 in src/ksp/ksp/impls/gmres/fgmres/fgmres.c [1]PETSC ERROR: KSPSolve_FGMRES() line 358 in src/ksp/ksp/impls/gmres/fgmres/fgmres.c [1]PETSC ERROR: KSPSolve() line 378 in src/ksp/ksp/interface/itfunc.c [1]PETSC ERROR: SNES_KSPSolve() line 2539 in src/snes/interface/snes.c [1]PETSC ERROR: SNESSolve_LS() line 184 in src/snes/impls/ls/ls.c [0]PETSC ERROR: SNESSolve() line 1867 in src/snes/interface/snes.c [0]PETSC ERROR: DMMGSolveSNES() line 510 in src/snes/utils/damgsnes.c [0]PETSC ERROR: DMMGSolve() line 393 in src/snes/utils/damg.c [0]PETSC ERROR: main() line 154 in src/snes/examples/tutorials/ex19.c [cli_0]: aborting job: application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0 impls/ls/ls.c [1]PETSC ERROR: SNESSolve() line 1867 in src/snes/interface/snes.c [1]PETSC ERROR: DMMGSolveSNES() line 510 in src/snes/utils/damgsnes.c [1]PETSC ERROR: DMMGSolve() line 393 in src/snes/utils/damg.c [1]PETSC ERROR: main() line 154 in src/snes/examples/tutorials/ex19.c [cli_1]: aborting job: application called MPI_Abort(MPI_COMM_WORLD, 1) - process 1 Graphics example src/snes/examples/tutorials/ex19 run successfully with 1 MPI process Fortran example src/snes/examples/tutorials/ex5f run successfully with 1 MPI process Completed test examples
---------------------------------------------------- Marc Spiegelman Lamont-Doherty Earth Observatory Dept. of Applied Physics/Applied Math Columbia University http://www.ldeo.columbia.edu/~mspieg ----------------------------------------------------
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Matthew Knepley
