Re: [petsc-dev] documentation webpage is broken
On Wed, 9 Feb 2011, Aron Ahmadia wrote:
link to the source of DMCreateGlobalVector from http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/docs/manualpages/D...
goes to a broken url: http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/src/dm/da/interfac...
the functional url is: http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/src/dm/interface/d...
Also, this really annoys me:
234: *PetscErrorCode <http://www.mcs.anl.gov/petsc/petsc-as/snapshots/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode> DMCreateGlobalVector <http://www.mcs.anl.gov/petsc/petsc-as/snapshots/docs/manualpages/DM/DMCreateGlobalVector.html#DMCreateGlobalVector>(DM <http://www.mcs.anl.gov/petsc/petsc-as/snapshots/docs/manualpages/DM/DM.html#DM> dm,Vec <http://www.mcs.anl.gov/petsc/petsc-as/snapshots/docs/manualpages/Vec/Vec.html#Vec> *vec)*235: { 239: (*dm->ops->createglobalvector)(dm,vec);240: return(0);241: }
pushed a fix - website will get updated tonight. [will see if the links are correct then]
I went through the documentation to find out how DMCreateGlobalVector is implemented. What's the mnemonic for finding the definition of the above function (or I guess, multiple definitions since this appears to be a 'virtual function' in C).
tags-search with emacs? satish
participants (1)
Satish Balay
