Re: [petsc-dev] Regression tests
On Thu, Jul 26, 2012 at 12:21 PM, Jed Brown <[email protected]> wrote:
Builder does some of this, but I think not all, and I don't think it's as convenient. The differences are partly syntactic. First, to add a test, you have to add lines to a single global file (currently 1500 lines). By creating the dictionary globally, we can't do consistency checks when the test is declared, instead you only do it later once you have lost line number information. You also can't build in the source directory, or anything similar, which makes it hard for a user to split an example out into their own toy project. Since you mess around with stdout, we are losing warning messages (including color) and lose some Emacs M-x compile convenience. (this can be fixed easily enough).
1) I am fine with changing where the options come from, meaning if we want to also check for an import somewhere. Personally, I think its easier to maintain a central database than a distributed database. I would only suggest a distributed database for scalability, which we do not need. 2) I take your point about users adding tests (extensibility), which is why I would be fine with checking for an import 3) I have no idea what you mean about consistency checks 4) You can run builder on source anywhere. This is how I check the crazy things people send us.
Note that my suggestion does not _prevent_ using a global script, but it localizes the declaration and would make it possible to run locally.
On Thu, Jul 26, 2012 at 11:37 AM, Matthew Knepley <[email protected]>wrote:
./test.py build ex19
$ config/builder2.py buildExample src/snes/examples/tutorials/ex19.c Namespace(files=['src/snes/examples/tutorials/ex19.c'], func=<function buildExample at 0x1fa56e0>) Building ['/home/jed/petsc/src/snes/examples/tutorials/ex19.c'] ERROR IN LINK ******************************
/usr/bin/ld: cannot find -lpetsc
collect2: error: ld returned 1 exit status
(maybe it doesn't work --with-single-library=0)
It does not. I don't see a reason to support this. If its does, it is accidental.
$ PETSC_ARCH=mpich-singlelib config/builder2.py buildExample src/snes/examples/tutorials/ex19.c Namespace(files=['src/snes/examples/tutorials/ex19.c'], func=<function buildExample at 0x25dd6e0>) Building ['/home/jed/petsc/src/snes/examples/tutorials/ex19.c']
(hmm, where is the executable anyway)
$ ls -ltr | tail -3 lrwxrwxrwx 1 jed users 35 Jul 26 11:57 make.log.bkp -> /home/jed/petsc/mpich/conf/make.log lrwxrwxrwx 1 jed users 45 Jul 26 11:58 make.log -> /home/jed/petsc/mpich-singlelib/conf/make.log -rw-r--r-- 1 jed users 5271714 Jul 26 11:58 RDict.log
(oh cool, it overwrote my library build with the make.log from this example)
It shouldn't. It should move make.log to make.log.bkp first. There must be a bug.
$ cat make.log Loaded configure to cache: size 298004 Building ['/home/jed/petsc/src/snes/examples/tutorials/ex19.c'] Compiling C files ['/home/jed/petsc/src/snes/examples/tutorials/ex19.c'] Pushing language C /opt/mpich2/bin/mpicc -c -I/home/jed/petsc/mpich-singlelib/include -I/home/jed/petsc/include -I/home/jed/petsc/mpich-singlelib/include -I/home/jed/usr/elemental-mpich/include -I/usr/include -I/opt/mpich2/include -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0 -MMD -D__INSDIR__= /home/jed/petsc/src/snes/examples/tutorials/ex19.c sh: /opt/mpich2/bin/mpicc -c -I/home/jed/petsc/mpich-singlelib/include -I/home/jed/petsc/include -I/home/jed/petsc/mpich-singlelib/include -I/home/jed/usr/elemental-mpich/include -I/usr/include -I/opt/mpich2/include -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0 -MMD -D__INSDIR__= /home/jed/petsc/src/snes/examples/tutorials/ex19.c Executing: /opt/mpich2/bin/mpicc -c -I/home/jed/petsc/mpich-singlelib/include -I/home/jed/petsc/include -I/home/jed/petsc/mpich-singlelib/include -I/home/jed/usr/elemental-mpich/include -I/usr/include -I/opt/mpich2/include -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0 -MMD -D__INSDIR__= /home/jed/petsc/src/snes/examples/tutorials/ex19.c sh: Popping language C Moving ex19.o to /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19.o Moving ex19.d to /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19.d Linking object ['/home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19.o'] into /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19 Pushing language C Pushing language C Popping language C Pushing language CUDA Popping language CUDA Pushing language Cxx Popping language Cxx Pushing language FC Popping language FC Pushing language C Popping language C sh: /opt/mpich2/bin/mpicc -o /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19 -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0 /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19.o -L/home/jed/petsc/mpich-singlelib/lib -lpetsc -Wl,-rpath,/home/jed/petsc/mpich-singlelib/lib -L/home/jed/petsc/mpich-singlelib/lib -ltriangle -lX11 -lchaco -lparmetis -lmetis -Wl,-rpath,/home/jed/usr/elemental-mpich/lib -L/home/jed/usr/elemental-mpich/lib -lelemental -lplcg -lpmrrr -lamspub -lml -Wl,-rpath,/opt/mpich2/lib -L/opt/mpich2/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1 -lmpichcxx -lstdc++ -lpthread -lblacs -lHYPRE -lmpichcxx -lstdc++ -Wl,-rpath,/usr/lib -L/usr/lib -lcholmod -lamd -lcolamd -lcamd -lccolamd -lumfpack -lcholmod -lcamd -lccolamd -lcolamd -lamd -llapack -lblas -lm -L/usr/local/cuda/lib -Wl,-rpath,/opt/mpich2/lib -L/opt/mpich2/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1 -ldl -Wl,-rpath,/opt/mpich2/lib -lmpich -lopa -lmpl -lpthread -lrt -lgcc_s -ldl Executing: /opt/mpich2/bin/mpicc -o /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19 -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0 /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19.o -L/home/jed/petsc/mpich-singlelib/lib -lpetsc -Wl,-rpath,/home/jed/petsc/mpich-singlelib/lib -L/home/jed/petsc/mpich-singlelib/lib -ltriangle -lX11 -lchaco -lparmetis -lmetis -Wl,-rpath,/home/jed/usr/elemental-mpich/lib -L/home/jed/usr/elemental-mpich/lib -lelemental -lplcg -lpmrrr -lamspub -lml -Wl,-rpath,/opt/mpich2/lib -L/opt/mpich2/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1 -lmpichcxx -lstdc++ -lpthread -lblacs -lHYPRE -lmpichcxx -lstdc++ -Wl,-rpath,/usr/lib -L/usr/lib -lcholmod -lamd -lcolamd -lcamd -lccolamd -lumfpack -lcholmod -lcamd -lccolamd -lcolamd -lamd -llapack -lblas -lm -L/usr/local/cuda/lib -Wl,-rpath,/opt/mpich2/lib -L/opt/mpich2/lib -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1 -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1 -ldl -Wl,-rpath,/opt/mpich2/lib -lmpich -lopa -lmpl -lpthread -lrt -lgcc_s -ldl sh: Popping language C
(the above output loses warnings)
Bug.
$ mpich-singlelib/lib/ex19-obj/ex19 -happy-running
./test.py check ex19_fas
$ PETSC_ARCH=mpich-singlelib config/builder2.py check --testnum 5 src/snes/examples/tutorials/ex19.c Namespace(args=[], files=['src/snes/examples/tutorials/ex19.c'], func=<function check at 0xfe17d0>, retain=False, testnum=5) All tests pass
(edit file, insert syntax error, re-run)
[same output as above]
./test.py check ex19_\* # run all the ex19 tests
./test.py check -n 16 --if '(X || Fortran) && !Complex'
How?
Internally it knows all these predicates like num processes, Fortran and complex. There is no command line syntax for it. I did not think there was for make either. You can do that from the run parameters at the op of builder.py. Matt
The last line would mean to run all tests requiring X or Fortran, but not complex, using up to 16 MPI processes total.
We could preserve "make runex19_fas" in the transition period, but I'd like to be able to do everything from test.py.
builder already does all of this, and more stuff for code generation.
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Matthew Knepley
