Re: [petsc-dev] hg diff question
On Wed, 23 Mar 2011, Matthew Knepley wrote:
On Wed, Mar 23, 2011 at 3:21 PM, Barry Smith <[email protected]> wrote:
hg diff src/makefile
How come there isn't an option to have it show the most recent set of changes? It seems I have to hunt down some "revision numbers" and type
them
in the request to get any useful information? How about something like
hg diff --last src/makefile
The closest I can find is
hg diff -r-2 src/makefile
which diffs against the first revision before tip. However, if you pull a bunch of revisions, there is no guarantee that is right. You can generate this diff before the pull using 'hg incoming', but I can't yet find a command to give me the last thing pulled down.
hg diff by default does diff with working dir. What you want is:
hg diff -c tip or hg diff -c -2
The relative-rev numbering is based on full changeset numbering from tip - and not selective-file-changeset nubmering - which is what Barry wants.. I don't know if that exists..
I will point out that this would be easy to write as an extension. We use a 'bsmithdiff' diff that first calls 'log' to get the sequence of changesets for this file, and then counts backwards.
Well this is what I have: function bsmithdiff { hg diff -c `hg log -l 1 --template '{node}' $1` } bsmithdiff src/makefile
participants (1)
Satish Balay
