Re: [petsc-dev] [petsc-users] gamg failure with petsc-dev
On 18/09/14 15:41, Mark Adams wrote:
Thanks for updating me Stephan,
This is a common problem. I'm surprised we have not seen it more.
Note, the problem with the solver dying when MatSetBlockSize is set (correctly). Is some sort of bug. You have Stokes and use FieldSplit, so GAMG is working on a 2D elasticity like problem. Is that correct? And the equations are ordered node first: [v0_x, v0_y, v1_x, v1_y, v2_x, ....] correct?
Correct - although we're not using FieldSplit because of historic reasons (the code predates fieldsplit) - but yes, it's the velocity block K of a Stokes system (K G; G^T 0) with variable viscosity. I finally figured out why the convergence was so much worse if we do set the block size: It turns out to do with the scaling of the number I put on the diagonal for the eliminated DOFs associated with strong bcs. This problem has free slip bcs and I eliminate the DOF associated with the normal component by zeroing out the row and column and putting an arbitrary number on the diagonal (I chose 1.0). Normally the number doesn't really matter as the row is completely decoupled from the rest of the system. However in this case, when using gamg with blocks, it affects the strong coupling criterion for *both* velocity components associated with the boundary node. This criterion is scaled with respect to the 1-norm of the diagonal block, thus if the diagonal for the normal component is chosen too big it also declares all connections to the dof associated with the tangential component weak. In this way all the boundary nodes (the pairs of velocity components at these nodes) became isolated clusters and were disregarded at the coarse level. After choosing a smaller value for the diagonals the solve now converges fine in roughly the same number of iterations as when not setting the block size. The tricky thing here is the choice of the dummy diagonal number becomes very sensitive - with a typical gamg threshold of 0.01 it can't be more than an order out. Currently I use MatZeroRowsColumns() with a constant value for the diagonal. Because I have a variable viscosity it seems I can no longer do that. Now I can just go in and look at what the diagonal is for the other component at each boundary node and use that value instead (or at least a value that's smaller) - but it all seems a bit hackish to me. Perhaps we're following the wrong approach altogether and should be dealing with the bcs in an other way? Any thoughts would be more than welcome... Cheers Stephan
participants (1)
Stephan Kramer
