Re: [petsc-dev] Open solaris 64bit printf bug?
Satish, Thanks. I have put in master and next. I totally missed those, I was only looking at PetscSectionView(() Barry
On Sep 3, 2015, at 11:30 PM, Satish Balay <[email protected]> wrote:
Perhaps the following is the fix?
Satish
------------- diff --git a/src/vec/vec/utils/vsection.c b/src/vec/vec/utils/vsection.c index 4923238..444c8ac 100644 --- a/src/vec/vec/utils/vsection.c +++ b/src/vec/vec/utils/vsection.c @@ -22,7 +22,7 @@ PetscErrorCode PetscSectionVecView_ASCII(PetscSection s, Vec v, PetscViewer view if ((s->bc) && (s->bc->atlasDof[p] > 0)) { PetscInt b;
- ierr = PetscViewerASCIISynchronizedPrintf(viewer, " (%4d) dim %2d offset %3d", p+s->pStart, s->atlasDof[p], s->atlasOff[p]);CHKERRQ(ierr); + ierr = PetscViewerASCIISynchronizedPrintf(viewer, " (%4D) dim %2D offset %3D", p+s->pStart, s->atlasDof[p], s->atlasOff[p]);CHKERRQ(ierr); for (i = s->atlasOff[p]; i < s->atlasOff[p]+s->atlasDof[p]; ++i) { PetscScalar v = array[i]; #if defined(PETSC_USE_COMPLEX) @@ -43,7 +43,7 @@ PetscErrorCode PetscSectionVecView_ASCII(PetscSection s, Vec v, PetscViewer view } ierr = PetscViewerASCIISynchronizedPrintf(viewer, "\n");CHKERRQ(ierr); } else { - ierr = PetscViewerASCIISynchronizedPrintf(viewer, " (%4d) dim %2d offset %3d", p+s->pStart, s->atlasDof[p], s->atlasOff[p]);CHKERRQ(ierr); + ierr = PetscViewerASCIISynchronizedPrintf(viewer, " (%4D) dim %2D offset %3D", p+s->pStart, s->atlasDof[p], s->atlasOff[p]);CHKERRQ(ierr); for (i = s->atlasOff[p]; i < s->atlasOff[p]+s->atlasDof[p]; ++i) { PetscScalar v = array[i]; #if defined(PETSC_USE_COMPLEX) @@ -87,7 +87,7 @@ PetscErrorCode PetscSectionVecView(PetscSection s, Vec v, PetscViewer viewer) if (s->numFields) { ierr = PetscViewerASCIIPrintf(viewer, "%s with %d fields\n", name, s->numFields);CHKERRQ(ierr); for (f = 0; f < s->numFields; ++f) { - ierr = PetscViewerASCIIPrintf(viewer, " field %d with %d components\n", f, s->numFieldComponents[f]);CHKERRQ(ierr); + ierr = PetscViewerASCIIPrintf(viewer, " field %D with %D components\n", f, s->numFieldComponents[f]);CHKERRQ(ierr); ierr = PetscSectionVecView_ASCII(s->field[f], v, viewer);CHKERRQ(ierr); } } else { --------------------
balay@n-gage:~/petsc.clone/src/dm/impls/plex/examples/tests$ make runex3_nonconforming_tensor_2 319,321c319,321 < Null vector 0 is likely null vector|| A * v[0] || = 8.64582e-17 < Null vector 1 is likely null vector|| A * v[1] || = 5.97914e-17 < Null vector 2 is likely null vector|| A * v[2] || = 7.89038e-17 ---
Null vector 0 is likely null vector|| A * v[0] || = 2.73185e-17 Null vector 1 is likely null vector|| A * v[1] || = 7.80433e-17 Null vector 2 is likely null vector|| A * v[2] || = 5.42673e-17 /home/balay/petsc.clone/src/dm/impls/plex/examples/tests Possible problem with with runex3_nonconforming_tensor_2, diffs above
On Thu, 3 Sep 2015, Barry Smith wrote:
And just to annoy me I cannot get -start_in_debugger to work on that machine. Valgrind has no complaints on a Mac with the examples.
I've found some miss-use of PetscViewerASCIIPushSynchronized() and %d in parts of plex, I don't see how they could cause this problem but I am fixing them and will push that. Maybe we'll get lucky.
Barry
On Sep 3, 2015, at 10:06 AM, Tobin Isaac <[email protected]> wrote:
Here's a partial diff from http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/09/03/examples_nex...:
232c232 < field 0 with 2 components ---
field 0 with 0 components 234,242c234,242 < ( 2) dim 2 offset 0 0.5 0 < ( 3) dim 2 offset 2 1 0 < ( 4) dim 2 offset 4 0 0.5 < ( 5) dim 2 offset 6 0.5 0.5 < ( 6) dim 2 offset 8 1 0.5 < ( 7) dim 2 offset 10 0 1 < ( 8) dim 2 offset 12 0.5 1 < ( 9) dim 2 offset 14 0.5 0.25 < ( 10) dim 2 offset 16 0.25 0.5
( 2) dim 0 offset 2 0.5 0 ( 3) dim 0 offset 2 1 0 ( 4) dim 0 offset 2 0 0.5 ( 5) dim 0 offset 2 0.5 0.5 ( 6) dim 0 offset 2 1 0.5 ( 7) dim 0 offset 2 0 1 ( 8) dim 0 offset 2 0.5 1 ( 9) dim 0 offset 2 0.5 0.25 ( 10) dim 0 offset 2 0.25 0.5
The numbers that printf is making 0 (or 2) clearly aren't, because they are used to iterate over a section and display its contents. But other PetscInt's are printed fine elsewhere. Weird.
Toby
participants (1)
Barry Smith
