Re: [petsc-dev] p4est w/o MPI
Ok. MPICH/OpenMPI could be used for sequential runs and parallel within node. [and not between nodes?] Satish On Fri, 16 Apr 2021, Mark Adams wrote:
On Fri, Apr 16, 2021 at 11:33 AM Satish Balay <[email protected]> wrote:
Mark, Why a no-mpi build on Fugaku?
Kokkos Kernels + OMP barfed and Kokkos suggested gcc. There does not seem to be an MPI for GCC here.
Toby - there is one more issue with p4est - build error when using --with-batch=1
Attaching configure.log
Satish
On Fri, 16 Apr 2021, Isaac, Tobin G wrote:
p4est has a mode where it can compile without MPI, I don't know if PETSc is using it, will check.
________________________________________ From: petsc-dev <[email protected]> on behalf of Mark Adams <[email protected]> Sent: Friday, April 16, 2021 10:23 To: For users of the development version of PETSc Subject: [petsc-dev] p4est w/o MPI
I don't have MPI (Fugaku w/ gcc) and p4est seems to need it. Is there a work around? Thanks, Mark
participants (1)
Satish Balay
