Re: [petsc-dev] Errors with DM & PCSHELL
On Fri, May 29, 2015 at 2:03 PM, Barry Smith <[email protected]> wrote:
On May 29, 2015, at 10:32 AM, Mark Adams <[email protected]> wrote:
I am getting errors in code that I thought was working ...
I create a PC shell like so:
! set shell PC call SNESGetKSP(solver%snes,innerksp,ierr) call KSPGetPC(innerksp,spc,ierr) call PCSetType(spc,PCSHELL,ierr) ! overriding opions !!! call PCShellSetApply(spc,PCShermanMorrisonApply,ierr) call PCSetApplicationContext(spc,solver,ierr)
and in PCShermanMorrisonApply I have:
call PCGetApplicationContext(pc,solver,ierr) call DMCompositeGetAccessArray(solver%da,xin,itwo,PETSC_NULL_INTEGER,Xsub,ierr) call DMCompositeGetAccessArray(solver%da,yout,itwo,PETSC_NULL_INTEGER,Ysub,ierr) call PCFieldSplitGetSubKSP(solver%pc,PETSC_NULL_INTEGER,subksp,ierr) call KSPSolve(subksp(1),Xsub(1),Ysub(1),ierr) call MatMult(solver%Cmat,Ysub(1),Xsub(2),ierr) ! ignoring <> input
I get an error on this last statement about a vector being locked.
What vector? the Xsub(2) vector?
Yes, arg #3
Based on the names of the variable I am guessing that xin is the input vector to your Apply() hence it is read only. Thus Xsub is read only, but you are trying to put the results of a MatMult() int Xsub(2) which is completely wrong. You cannot use Xsub for work space because it will corrupt the outer solver.
There does not seem to be:
call DMCompositeGetAccessArrayRead( ...
There doesn't need to be. Internally the DMCompositeGetAccessArray() will make the subvectors read only if the large vector is read only.
OK, but I am getting an error. This is it. Line 2218 here is (not clear what is going on here, a macro?): VecLocked(y,3); [8]PETSC ERROR: Vec is locked read only, argument # 3 [8]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [8]PETSC ERROR: Petsc Development GIT revision: v3.5.4-3050-g7d7ead0 GIT Date: 2015-05-28 23:28:47 -0500 [8]PETSC ERROR: /global/homes/m/madams/epsi/XGC1_3/xgc-es on a arch-xc30-dbg-intel named nid05966 by madams Fri May 29 12:56:27 2015 [8]PETSC ERROR: Configure options --COPTFLAGS="-no-ipo -g -O0" --CXXOPTFLAGS="-no-ipo -g -O0" --FOPTFLAGS="-no-ipo -g -O0" --download-parmetis --download-metis --with-cc=cc --with-clib-autodetect=0 --with-cxx=CC --with-cxxlib-autodetect=0 --with-debugging=1 --with-fc=ftn --with-fortranlib-autodetect=0 --with-hdf5-dir=/opt/cray/hdf5-parallel/1.8.13/intel/140/ --with-shared-libraries=0 --with-x=0 --with-mpiexec=aprun LIBS=-lstdc++ PETSC_ARCH=arch-xc30-dbg-intel [8]PETSC ERROR: #1 MatMult() line 2218 in /global/u2/m/madams/petsc/src/mat/interface/matrix.c
I thought I fixed this problem ... or at least one like it.
participants (1)
Mark Adams
