Re: [petsc-dev] Regression in manualpages generation?
I think this was likely a non-portable regex that was being used to match the function signatures, causing it to miss anything with an internal "s" in the function name. Here's a quick fix for the release branch: https://gitlab.com/petsc/petsc/-/merge_requests/3813 (This sort of thing will become easier to work with, soon, as we'll have an automated doc build which can be examined for each MR.) P.S. nice email address!
Am 03.04.2021 um 11:19 schrieb Patrick Sanan <[email protected]>:
That isn't expected - thanks for pointing this out! I can reproduce locally so will take a look.
Am 03.04.2021 um 11:10 schrieb Pierre Jolivet <[email protected] <mailto:[email protected]>>:
Hello, https://www.mcs.anl.gov/petsc/petsc-3.14/docs/manualpages/Mat/MatTranspose.h... <https://www.mcs.anl.gov/petsc/petsc-3.14/docs/manualpages/Mat/MatTranspose.html> lists available implementations while https://www.mcs.anl.gov/petsc/petsc-3.15/docs/manualpages/Mat/MatTranspose.h... <https://www.mcs.anl.gov/petsc/petsc-3.15/docs/manualpages/Mat/MatTranspose.html> doesn’t. Is this expected?
Thanks, Pierre
participants (1)
Patrick Sanan
