Re: [petsc-dev] A closer look at the Xeon Phi
Hi Jed,
Which crossover are you referring to? The CPU versus GTX285 at about 20k dofs, but with only very small gains for another order of magnitude?
I assume it's the cross-over of Xeon Phi vs. Xeon,
MIC is slower than Xeon by more than an order of magnitude at 10k dofs.
Tim was referring to the cross-over at >10k...
but almost all cross-overs happen in the 10k-100k region and are due to PCI-Express latency.
Why is PCI-Express latency important here? Can't the MIC code run entirely on the device?
Almost-all (OpenCL, CUDA). Native mode ought to be the exception, but it's the OpenMP overhead which limits then. Single-core on the MIC is not really an option either... It would be interesting to play with a pthreads-threadpool implementation on the MIC to see how much performance can really be obtained for smallish problems. Best regards, Karli
participants (1)
Karl Rupp
