Re: [petsc-dev] Comparing binary output files in test harness
Could you file a gitlab issue on this? Offhand, I think it'd be best to modify petscdiff to check the suffix and then pass it off to exodiff. This would be more easily extended to other file types (e.g., h5diff). Scott On 2021-02-19 04:59, Blaise A Bourdin did write:
I would like to write better tests for my exodus I/O functions and compare the binary files written to the drive instead of the output of the examples. For instance, would it be possible to do the following: ex26 -i <input mesh> -o output1.exo; mpirun -np 2 ex26 -i <input mesh> -o output2.exo; exodiff output1.exo output2.exo And check the result of exodiff, or run exodiff between output1.exo or output2.exo and a stored binary result?
Regards, Blaise
-- A.K. & Shirley Barton Professor of Mathematics Adjunct Professor of Mechanical Engineering Adjunct of the Center for Computation & Technology Louisiana State University, Lockett Hall Room 344, Baton Rouge, LA 70803, USA Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 Web http://www.math.lsu.edu/~bourdin
-- Scott Kruger Tech-X Corporation [email protected] 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196 Boulder, CO 80303 Fax: (303) 448-7756
participants (1)
Scott Kruger
