On Mon, Jul 13, 2020 at 3:55 PM Mark Adams <[email protected]> wrote:
It's been fixed and it's in my F90 test.
Did you take out the -fallow_... ? Matt
On Mon, Jul 13, 2020 at 3:54 PM Matthew Knepley <[email protected]> wrote:
On Mon, Jul 13, 2020 at 3:50 PM Mark Adams <[email protected]> wrote:
On Mon, Jul 13, 2020 at 1:40 PM Jed Brown <[email protected]> wrote:
I don't know what failure you're referring to. The C++ complex thing might have been a matter of the antique compiler.
The failure was fixed with -fallow_ .... but it gave warnings.
Mark, can you try Barry's fix, changing the declaration of PetscObjectSetName()?
Matt
Matthew Knepley <[email protected]> writes:
Why did Mark have the gcc 10 failure on our example. Was it something with did in it?
Matt
On Mon, Jul 13, 2020 at 12:43 PM Jed Brown <[email protected]> wrote:
You want this for PETSc or for external packages? We add it for a bunch of external packages. I've been building PETSc with gcc/gfortran-10 for months now.
Do we have gfortran from gcc 10 running anywhere? We need a check to enable
-fallow-argument-mismatch
from configure. Should be as simple as compiling Fortran which has PetscObjectSetName() in it.
Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ < http://www.cse.buffalo.edu/~knepley/>
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
participants (1)
Matthew Knepley
