Hi everybody, I am trying to install PETSc version 3.10.3 on OSX Sierra 10.13.6 with the following configure options ./configure --CC=mpicc --CXX=mpicxx --FC=mpif90 --PETSC_ARCH=sierra-dbg --with-debugging=1 --download-hypre=1 --with-x=0 however I am getting the following error messages when I do 'make check'. See below the resulting message. Any suggestions? Thanks, --Panos panos@Sierra-iMac:~/Softwares/PETSc-Bitbucket/PETSc$ make PETSC_DIR=/Users/panos/Softwares/PETSc-Bitbucket/PETSc PETSC_ARCH=sierra-dbg check Running test examples to verify correct installation Using PETSC_DIR=/Users/panos/Softwares/PETSc-Bitbucket/PETSc and PETSC_ARCH=sierra-dbg make[2]: [ex19.PETSc] Error 2 (ignored) *******************Error detected during compile or link!******************* See http://www.mcs.anl.gov/petsc/documentation/faq.html /Users/panos/Softwares/PETSc-Bitbucket/PETSc/src/snes/examples/tutorials ex19 ********************************************************************************* mpicc -o ex19.o -c -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -Qunused-arguments -fvisibility=hidden -g3 -I/Users/panos/Softwares/PETSc-Bitbucket/PETSc/include -I/Users/panos/Softwares/PETSc-Bitbucket/PETSc/sierra-dbg/include `pwd`/ex19.c mpicc -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -Qunused-arguments -fvisibility=hidden -g3 -o ex19 ex19.o -Wl,-rpath,/Users/panos/Softwares/PETSc-Bitbucket/PETSc/sierra-dbg/lib -L/Users/panos/Softwares/PETSc-Bitbucket/PETSc/sierra-dbg/lib -Wl,-rpath,/Users/panos/Softwares/PETSc-Bitbucket/PETSc/sierra-dbg/lib -L/Users/panos/Softwares/PETSc-Bitbucket/PETSc/sierra-dbg/lib -Wl,-rpath,/usr/local/Cellar/mpich/3.3/lib -L/usr/local/Cellar/mpich/3.3/lib -Wl,-rpath,/usr/local/Cellar/gcc/8.3.0/lib/gcc/8/gcc/x86_64-apple-darwin17.7.0/8.3.0 -L/usr/local/Cellar/gcc/8.3.0/lib/gcc/8/gcc/x86_64-apple-darwin17.7.0/8.3.0 -Wl,-rpath,/usr/local/Cellar/gcc/8.3.0/lib/gcc/8 -L/usr/local/Cellar/gcc/8.3.0/lib/gcc/8 -Wl,-rpath,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries -L/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries -Wl,-rpath,/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources -L/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources -Wl,-rpath,/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources -L/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources -lpetsc -lHYPRE -ldl -lmpifort -lmpi -lpmpi -lgfortran -lquadmath -lm -lGFXShared -lGLU -lGL -lGLImage -lCVMSPluginSupport -lFontParser -lFontRegistry -lJPEG -lTIFF -lPng -lGIF -lJP2 -lRadiance -lCoreVMClient -ldl ld: warning: text-based stub file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.tbd and library file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.tbd and library file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.tbd and library file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.tbd and library file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.tbd and library file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.tbd and library file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.tbd and library file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.tbd and library file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.tbd and library file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.tbd and library file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.tbd and library file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.tbd and library file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.tbd and library file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.tbd and library file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//CoreFoundation.framework/Versions/A/CoreFoundation.tbd and library file /System/Library/Frameworks//CoreFoundation.framework/Versions/A/CoreFoundation are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//IOKit.framework/Versions/A/IOKit.tbd and library file /System/Library/Frameworks//IOKit.framework/Versions/A/IOKit are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator.tbd and library file /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//ApplicationServices.framework/Versions/A/ApplicationServices.tbd and library file /System/Library/Frameworks//ApplicationServices.framework/Versions/A/ApplicationServices are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//CoreGraphics.framework/Versions/A/CoreGraphics.tbd and library file /System/Library/Frameworks//CoreGraphics.framework/Versions/A/CoreGraphics are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//Security.framework/Versions/A/Security.tbd and library file /System/Library/Frameworks//Security.framework/Versions/A/Security are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//CoreServices.framework/Versions/A/CoreServices.tbd and library file /System/Library/Frameworks//CoreServices.framework/Versions/A/CoreServices are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//Foundation.framework/Versions/C/Foundation.tbd and library file /System/Library/Frameworks//Foundation.framework/Versions/C/Foundation are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//OpenCL.framework/Versions/A/OpenCL.tbd and library file /System/Library/Frameworks//OpenCL.framework/Versions/A/OpenCL are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//IOSurface.framework/Versions/A/IOSurface.tbd and library file /System/Library/Frameworks//IOSurface.framework/Versions/A/IOSurface are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//CoreText.framework/Versions/A/CoreText.tbd and library file /System/Library/Frameworks//CoreText.framework/Versions/A/CoreText are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//ImageIO.framework/Versions/A/ImageIO.tbd and library file /System/Library/Frameworks//ImageIO.framework/Versions/A/ImageIO are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS.tbd and library file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices.tbd and library file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis.tbd and library file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//CFNetwork.framework/Versions/A/CFNetwork.tbd and library file /System/Library/Frameworks//CFNetwork.framework/Versions/A/CFNetwork are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices.tbd and library file /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices.tbd and library file /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList.tbd and library file /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//DiskArbitration.framework/Versions/A/DiskArbitration.tbd and library file /System/Library/Frameworks//DiskArbitration.framework/Versions/A/DiskArbitration are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//OpenGL.framework/Versions/A/OpenGL.tbd and library file /System/Library/Frameworks//OpenGL.framework/Versions/A/OpenGL are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//CoreAudio.framework/Versions/A/CoreAudio.tbd and library file /System/Library/Frameworks//CoreAudio.framework/Versions/A/CoreAudio are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//AudioToolbox.framework/Versions/A/AudioToolbox.tbd and library file /System/Library/Frameworks//AudioToolbox.framework/Versions/A/AudioToolbox are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory.tbd and library file /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//ServiceManagement.framework/Versions/A/ServiceManagement.tbd and library file /System/Library/Frameworks//ServiceManagement.framework/Versions/A/ServiceManagement are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS.tbd and library file /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS are out of sync. Falling back to library file for linking. Undefined symbols for architecture x86_64: "_jpeg_CreateCompress", referenced from: import-atom in libpetsc.dylib "_jpeg_destroy_compress", referenced from: import-atom in libpetsc.dylib "_jpeg_finish_compress", referenced from: import-atom in libpetsc.dylib "_jpeg_set_defaults", referenced from: import-atom in libpetsc.dylib "_jpeg_start_compress", referenced from: import-atom in libpetsc.dylib "_jpeg_std_error", referenced from: import-atom in libpetsc.dylib "_jpeg_stdio_dest", referenced from: import-atom in libpetsc.dylib "_jpeg_write_scanlines", referenced from: import-atom in libpetsc.dylib "_png_create_info_struct", referenced from: import-atom in libpetsc.dylib "_png_create_write_struct", referenced from: import-atom in libpetsc.dylib "_png_destroy_write_struct", referenced from: import-atom in libpetsc.dylib "_png_init_io", referenced from: import-atom in libpetsc.dylib "_png_set_IHDR", referenced from: import-atom in libpetsc.dylib "_png_set_PLTE", referenced from: import-atom in libpetsc.dylib "_png_set_longjmp_fn", referenced from: import-atom in libpetsc.dylib "_png_write_end", referenced from: import-atom in libpetsc.dylib "_png_write_info", referenced from: import-atom in libpetsc.dylib "_png_write_row", referenced from: import-atom in libpetsc.dylib ld: symbol(s) not found for architecture x86_64 clang: error: linker command failed with exit code 1 (use -v to see invocation) make[3]: [ex19] Error 1 (ignored) /usr/bin/dsymutil ex19 error: cannot parse the debug map for 'ex19': No such file or directory make[3]: *** [ex19] Error 1 rm ex19.o 1,5c1,2 < lid velocity = 0.0016, prandtl # = 1., grashof # = 1. < 0 SNES Function norm 0.0406612 < 1 SNES Function norm 4.12227e-06 < 2 SNES Function norm 6.098e-11 < Number of SNES iterations = 2 ---
[proxy:0:[email protected]] HYDU_create_process (utils/launch/launch.c:74): execvp error on file ./ex19 (No such file or directory) [proxy:0:[email protected]] HYDU_create_process (utils/launch/launch.c:74): execvp error on file ./ex19 (No such file or directory) /Users/panos/Softwares/PETSc-Bitbucket/PETSc/src/snes/examples/tutorials Possible problem with ex19_hypre, diffs above ========================================= *******************Error detected during compile or link!******************* See http://www.mcs.anl.gov/petsc/documentation/faq.html /Users/panos/Softwares/PETSc-Bitbucket/PETSc/src/snes/examples/tutorials ex5f
mpif90 -c -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -I/Users/panos/Softwares/PETSc-Bitbucket/PETSc/include -I/Users/panos/Softwares/PETSc-Bitbucket/PETSc/sierra-dbg/include -o ex5f.o ex5f.F90 mpif90 -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -Wl,-no_compact_unwind -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -o ex5f ex5f.o -Wl,-rpath,/Users/panos/Softwares/PETSc-Bitbucket/PETSc/sierra-dbg/lib -L/Users/panos/Softwares/PETSc-Bitbucket/PETSc/sierra-dbg/lib -Wl,-rpath,/Users/panos/Softwares/PETSc-Bitbucket/PETSc/sierra-dbg/lib -L/Users/panos/Softwares/PETSc-Bitbucket/PETSc/sierra-dbg/lib -Wl,-rpath,/usr/local/Cellar/mpich/3.3/lib -L/usr/local/Cellar/mpich/3.3/lib -Wl,-rpath,/usr/local/Cellar/gcc/8.3.0/lib/gcc/8/gcc/x86_64-apple-darwin17.7.0/8.3.0 -L/usr/local/Cellar/gcc/8.3.0/lib/gcc/8/gcc/x86_64-apple-darwin17.7.0/8.3.0 -Wl,-rpath,/usr/local/Cellar/gcc/8.3.0/lib/gcc/8 -L/usr/local/Cellar/gcc/8.3.0/lib/gcc/8 -Wl,-rpath,/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries -L/System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries -Wl,-rpath,/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources -L/System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources -Wl,-rpath,/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources -L/System/Library/Frameworks/ImageIO.framework/Versions/A/Resources -lpetsc -lHYPRE -ldl -lmpifort -lmpi -lpmpi -lgfortran -lquadmath -lm -lGFXShared -lGLU -lGL -lGLImage -lCVMSPluginSupport -lFontParser -lFontRegistry -lJPEG -lTIFF -lPng -lGIF -lJP2 -lRadiance -lCoreVMClient -ldl ld: warning: text-based stub file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.tbd and library file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.tbd and library file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.tbd and library file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.tbd and library file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.tbd and library file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.tbd and library file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.tbd and library file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.tbd and library file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.tbd and library file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.tbd and library file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.tbd and library file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.tbd and library file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.tbd and library file /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.tbd and library file /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//CoreFoundation.framework/Versions/A/CoreFoundation.tbd and library file /System/Library/Frameworks//CoreFoundation.framework/Versions/A/CoreFoundation are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//IOKit.framework/Versions/A/IOKit.tbd and library file /System/Library/Frameworks//IOKit.framework/Versions/A/IOKit are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator.tbd and library file /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//ApplicationServices.framework/Versions/A/ApplicationServices.tbd and library file /System/Library/Frameworks//ApplicationServices.framework/Versions/A/ApplicationServices are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//CoreGraphics.framework/Versions/A/CoreGraphics.tbd and library file /System/Library/Frameworks//CoreGraphics.framework/Versions/A/CoreGraphics are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//Security.framework/Versions/A/Security.tbd and library file /System/Library/Frameworks//Security.framework/Versions/A/Security are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//CoreServices.framework/Versions/A/CoreServices.tbd and library file /System/Library/Frameworks//CoreServices.framework/Versions/A/CoreServices are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//Foundation.framework/Versions/C/Foundation.tbd and library file /System/Library/Frameworks//Foundation.framework/Versions/C/Foundation are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//OpenCL.framework/Versions/A/OpenCL.tbd and library file /System/Library/Frameworks//OpenCL.framework/Versions/A/OpenCL are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//IOSurface.framework/Versions/A/IOSurface.tbd and library file /System/Library/Frameworks//IOSurface.framework/Versions/A/IOSurface are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//CoreText.framework/Versions/A/CoreText.tbd and library file /System/Library/Frameworks//CoreText.framework/Versions/A/CoreText are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//ImageIO.framework/Versions/A/ImageIO.tbd and library file /System/Library/Frameworks//ImageIO.framework/Versions/A/ImageIO are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS.tbd and library file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices.tbd and library file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis.tbd and library file /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//CFNetwork.framework/Versions/A/CFNetwork.tbd and library file /System/Library/Frameworks//CFNetwork.framework/Versions/A/CFNetwork are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices.tbd and library file /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices.tbd and library file /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList.tbd and library file /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//DiskArbitration.framework/Versions/A/DiskArbitration.tbd and library file /System/Library/Frameworks//DiskArbitration.framework/Versions/A/DiskArbitration are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//OpenGL.framework/Versions/A/OpenGL.tbd and library file /System/Library/Frameworks//OpenGL.framework/Versions/A/OpenGL are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//CoreAudio.framework/Versions/A/CoreAudio.tbd and library file /System/Library/Frameworks//CoreAudio.framework/Versions/A/CoreAudio are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//AudioToolbox.framework/Versions/A/AudioToolbox.tbd and library file /System/Library/Frameworks//AudioToolbox.framework/Versions/A/AudioToolbox are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory.tbd and library file /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/Frameworks//ServiceManagement.framework/Versions/A/ServiceManagement.tbd and library file /System/Library/Frameworks//ServiceManagement.framework/Versions/A/ServiceManagement are out of sync. Falling back to library file for linking. ld: warning: text-based stub file /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS.tbd and library file /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS are out of sync. Falling back to library file for linking. Undefined symbols for architecture x86_64: "_jpeg_CreateCompress", referenced from: import-atom in libpetsc.dylib "_jpeg_destroy_compress", referenced from: import-atom in libpetsc.dylib "_jpeg_finish_compress", referenced from: import-atom in libpetsc.dylib "_jpeg_set_defaults", referenced from: import-atom in libpetsc.dylib "_jpeg_start_compress", referenced from: import-atom in libpetsc.dylib "_jpeg_std_error", referenced from: import-atom in libpetsc.dylib "_jpeg_stdio_dest", referenced from: import-atom in libpetsc.dylib "_jpeg_write_scanlines", referenced from: import-atom in libpetsc.dylib "_png_create_info_struct", referenced from: import-atom in libpetsc.dylib "_png_create_write_struct", referenced from: import-atom in libpetsc.dylib "_png_destroy_write_struct", referenced from: import-atom in libpetsc.dylib "_png_init_io", referenced from: import-atom in libpetsc.dylib "_png_set_IHDR", referenced from: import-atom in libpetsc.dylib "_png_set_PLTE", referenced from: import-atom in libpetsc.dylib "_png_set_longjmp_fn", referenced from: import-atom in libpetsc.dylib "_png_write_end", referenced from: import-atom in libpetsc.dylib "_png_write_info", referenced from: import-atom in libpetsc.dylib "_png_write_row", referenced from: import-atom in libpetsc.dylib ld: symbol(s) not found for architecture x86_64 collect2: error: ld returned 1 exit status make[3]: [ex5f] Error 1 (ignored) rm ex5f.o Completed test examples
participants (1)
DAFNAKIS PANAGIOTIS
