Re: [petsc-dev] [GPU] SEGV with: mpiexec -np 2 ./ex2 -ksp_type cg -m 10 -n 10 -pc_type bjacobi -sub_pc_type jacobi -mat_type aijcusp -vec_type cusp
Another crash when using ex2 (src/ksp/ksp/examples/tutorials) in parallel on GPU, when playing with precondtionners:
mpiexec -np 1 ./ex2 -ksp_type cg -m 10 -n 10 -pc_type bjacobi -sub_pc_type jacobi Norm of error 5.71895e-06 iterations 14 mpiexec -np 1 ./ex2 -ksp_type cg -m 10 -n 10 -pc_type bjacobi -sub_pc_type jacobi -mat_type aijcusp -vec_type cusp Norm of error 5.71895e-06 iterations 14 mpiexec -np 2 ./ex2 -ksp_type cg -m 10 -n 10 -pc_type bjacobi -sub_pc_type jacobi Norm of error 5.71895e-06 iterations 14 mpiexec -np 2 ./ex2 -ksp_type cg -m 10 -n 10 -pc_type bjacobi -sub_pc_type jacobi -mat_type aijcusp -vec_type cusp [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run [0]PETSC ERROR: to get more information on the crash. [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
Whereas the last one should work exactly as: mpiexec -np 2 ./ex2 -ksp_type cg -m 10 -n 10 -pc_type jacobi -mat_type aijcusp -vec_type cusp Norm of error 5.71895e-06 iterations 14
Or I miss something ?
this is a known problem with block-jacobi for which Dominic created a pull request here: https://bitbucket.org/petsc/petsc/pull-request/178/make-cusp-and-cusparse-so... I was talking to Dominic yesterday and we plan to get the series of GPU-related pull requests merged into next and master within the next couple of days. If it's urgent, please try that feature branch in the meanwhile. Best regards, Karli
participants (1)
Karl Rupp
