Re: [petsc-dev] C++ error with just PETSc includes
Thanks, (off list) I've got a git problem. I rebased over master a few times in the past week (including this AM). The first time I did this I got a lot of conflicts from DM partitioner routines that I fixed manually, and after that these rebases were smooth. Today I made some fixes on another machine and pushed them. You had given me the idiom 'git pull --rebase; git push', but I did not do this. I think this caused a massive problem. I tried rebasing aging over master from my home machine and I got all kinds of conflicts, starting with these DM partitioning things. I started fixing these again and was getting conflicts as git replay commits, over and over. I gave up eventually. So I am stuck. Is there something like a fix of history that is causing this problem, plz. This is branch adams/feature-dmplex-snes-landau. The real diffs are in plex and the two plex header files. Thanks again, Mark On Mon, Jul 13, 2020 at 11:24 AM Satish Balay <[email protected]> wrote:
Checking src/mat/tests/ex231.cxx you need:
diff --git a/src/dm/impls/plex/landau/kokkos/tutorials/ex1.cxx b/src/dm/impls/plex/landau/kokkos/tutorials/ex1.cxx index d04eaf96e7..967efc3625 100644 --- a/src/dm/impls/plex/landau/kokkos/tutorials/ex1.cxx +++ b/src/dm/impls/plex/landau/kokkos/tutorials/ex1.cxx @@ -1,5 +1,7 @@ static char help[] = "Simple Kokkos test\n\n";
+#define PETSC_SKIP_CXX_COMPLEX_FIX #include <petscdmplex.h>
Also #requiresdefine is not meant for example makefile. You can use:
build: requires: in /*TEST section
Satish
On Mon, 13 Jul 2020, Mark Adams wrote:
I have a wip C++ test that just calls PetscInitialize and Finalize, and I am getting some sort of error in the include file:
https://gitlab.com/petsc/petsc/-/jobs/635768809
All I do is:
Any ideas? Thanks, Mark
participants (1)
Mark Adams
