FFI trouble in instancing Vec's
I have wrapped a couple of elementary Vec allocation functions which typecheck in the host language but are not seemingly accepted by the library. In the host language, I called "VecCreate" on communicator 1, then used VecSet to set it to value 1.0 . What do errors #1 to #4 mean? In particular, error #4 points to this line in rvector.c : PetscValidHeaderSpecific(x,VEC_CLASSID,1); Which one is parameter #1 referred to by "Null Object" ? Does "Null argument" in the line before refer to the same error as the Null Object? And, how may I fix it? [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Null argument, when expecting valid pointer [0]PETSC ERROR: Null Object: Parameter # 1 [0]PETSC ERROR: Petsc Release Version 3.5.3, Jan, 31, 2015 [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --with-shared-libraries=1 --download-mpich --download-fblaslapack [0]PETSC ERROR: #1 PetscCommDuplicate() line 140 in /Users/ocramz/petsc-3.5.3/src/sys/objects/tagm.c [0]PETSC ERROR: #2 PetscHeaderCreate_Private() line 59 in /Users/ocramz/petsc-3.5.3/src/sys/objects/inherit.c [0]PETSC ERROR: #3 VecCreate() line 37 in /Users/ocramz/petsc-3.5.3/src/vec/vec/interface/veccreate.c [0]PETSC ERROR: #4 VecSet() line 569 in /Users/ocramz/petsc-3.5.3/src/vec/vec/interface/rvector.c
participants (1)
Marco Zocca
