Re: [petsc-dev] PetscLogView vs. -log_summary
On Thu, Jun 21, 2012 at 4:16 PM, Barry Smith <[email protected]> wrote:
On Jun 21, 2012, at 3:40 PM, Matthew Knepley wrote:
On Thu, Jun 21, 2012 at 2:08 PM, Blaise Bourdin <[email protected]> wrote:
On Jun 21, 2012, at 2:55 PM, Matthew Knepley wrote:
On Thu, Jun 21, 2012 at 1:11 PM, Blaise Bourdin <[email protected]> wrote: Hi,
PetscLogView does not display the same amount of information as running with -log_summary. In the "summary of stages" section, the former contains only information on the main stage while the later contains much more.
Add the following block at the end of src/snes/examples/tutorials/ex1.c, for instance, to see what I mean PetscViewer viewer; ierr = PetscViewerASCIIOpen(PETSC_COMM_WORLD,"ex1-log.py",&viewer);CHKERRQ(ierr); ierr = PetscLogViewPython(viewer);CHKERRQ(ierr); ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr); ierr = PetscViewerASCIIOpen(PETSC_COMM_WORLD,"ex1-log.txt",&viewer);CHKERRQ(ierr); ierr = PetscLogView(viewer);CHKERRQ(ierr); ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr); ierr = PetscLogPrintDetailed(PETSC_COMM_WORLD,"ex1-logdetailed.txt");CHKERRQ(ierr);
Is this a bug or a feature? Is there a way to get the same output as -log_summary in a file, without printing it to stdout?
-log_summary just calls PetscLogView(). I am not sure how there could be a problem. I will run it. However, can you just use
-log_summary <filename>
That works, yes. Is the issue that stages / events need to be activated a priori, which is not possible when PetscLogView is only called at the end of the program?
Crap.
Matt, why is this "Crap" its completely reasonable that if you want to have logging from program control that you have to turn it on programatically?
Crap, because I should have remembered earlier. Matt
If you do not provide -log_summary, you need PetscLogBegin() at the beginning.
Matt
The caveat is that I am assuming that when using log_summary, the log is written as part of PetscFinalize, so that if a job is killed by the sceduler or the user, there is no way to get an idea of the performances. I like to print the log every so often.
Blaise
-- Department of Mathematics and Center for Computation & Technology Louisiana State University, Baton Rouge, LA 70803, USA Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Matthew Knepley
