Re: [petsc-dev] Is ./configure --help broken?
On Fri, 16 Mar 2018, Satish Balay wrote:
On Fri, 16 Mar 2018, Matthew Knepley wrote:
This works for me. Do you want to put it in your branch, or should I check it in?
Matt
diff --git a/config/BuildSystem/RDict.py b/config/BuildSystem/RDict.py index 2dc745f..efc8b81 100755 --- a/config/BuildSystem/RDict.py +++ b/config/BuildSystem/RDict.py @@ -218,7 +218,7 @@ Arg class, which wraps the usual value.''' print '----------------------------------------------------------- ------------' pass dict.__setitem__(self, key, value) - self.save() + self.save(force = 0) else: return self.send(key, value) return
How about reducing the number of times save is called - i.e try calling it only once at the end. Would that work?
diff --git a/config/BuildSystem/RDict.py b/config/BuildSystem/RDict.py index 2dc745f1aa..98a2a16a29 100755 --- a/config/BuildSystem/RDict.py +++ b/config/BuildSystem/RDict.py @@ -195,7 +195,7 @@ Arg class, which wraps the usual value.''' else: self.writeLogLine('__getitem__: Setting local type for '+key) dict.__setitem__(self, key, nargs.Arg(key)) - self.save() + #self.save() self.writeLogLine('__getitem__: Setting local value for '+key) return dict.__getitem__(self, key).getValue()
@@ -218,7 +218,7 @@ Arg class, which wraps the usual value.''' print '----------------------------- ------------------------------------------' pass dict.__setitem__(self, key, value) - self.save() + #self.save() else: return self.send(key, value) return @@ -232,14 +232,14 @@ Arg class, which wraps the usual value.''' dict.__setitem__(self, key, nargs.Arg(key)) dict.__getitem__(self, key).setValue(value) self.writeLogLine('__setitem__: Set value for '+key+' to '+str(dict.__getitem__(self, key))) - self.save() + #self.save() return
def __delitem__(self, key): '''Checks for the key locally, and if not found consults the parent. Deletes the Arg completely.''' if dict.has_key(self, key): dict.__delitem__(self, key) - self.save() + #self.save() elif not self.parent is None: self.send(key) return @@ -248,7 +248,7 @@ Arg class, which wraps the usual value.''' '''Clears both the local and parent dictionaries''' if dict.__len__(self): dict.clear(self) - self.save() + #self.save() if not self.parent is None: self.send() return
My simple 'configure --prefix && make && make install' test appears to work with the above change - but don't know if the random crashes in nightlybuilds will come back or not..
I do not want to do that until its rewritten. There is already a save call at the end which was not working.
I suspect the issue is with the skip timmer with save(force=0) sometimes interfering with the safe(force=1) call at the end.
Hence my attempt to eliminate save(force=0) calls..
We haven't yet resolved this issue. I'd like to get a fix in which won't bring back the random Rdict.db errors.. Thanks, Satish
participants (1)
Satish Balay
