Re: [petsc-dev] Backend independent VecGetArray for GPUs
Thanks Karl! Ashwin On Sun, Oct 19, 2014 at 9:45 AM, Karl Rupp <[email protected]> wrote:
Hi Ashwin,
I'll add two functions returning the bare CUDA and OpenCL handles.
Best regards, Karli
On 10/19/2014 03:42 PM, Ashwin Srinath wrote:
Hi everyone
Just wondering what the consensus is. I'm happy to submit a PR if someone can tell me what goes where!
Thanks Ashwin
On 18 Oct 2014 01:46, "Karl Rupp" <[email protected] <mailto:[email protected]>> wrote:
>> > Why would we want this? The packages themselves (CUDA/ViennaCL) only
expose memory using these specific types. What use is it to wrap these up in a void * if you just have to caste back down to use them. Isn't it better to maintain type-specific, and type safe, interfaces for this stuff?
The biggest problem I faced was that there was no way to access device memory using petsc4py - since there is no equivalent for VecCUSPGetArray. So returning a raw pointer may not be very helpful for C++/CUSP users (they already have a nice way to access device memory) but it would definitely make things a lot easier for Python users.
To me it sounds like something that should be dealt with in the library that does the python bindings, not in PETSc itself. (...)
Unfortunately, this is not so easy: If the Python wrapper has to take care of such a conversion, then it needs to use the *exactly same build environment* as PETSc. The reason is that the CUSP and ViennaCL types are C++ beasts, not having a defined ABI, so one can run into all sorts of hard-to-debug problems when finally linking libpetsc.so with the Python wrapper. If, however, PETSc provides these low-level memory buffers, the Python wrapper can attach to a well-defined ABI.
Best regards, Karli
participants (1)
Ashwin Srinath
