Re: [petsc-dev] MacOS firewall annoyance while running tests + solution
28 Aug
28 Aug
'20
3:47 p.m.
"Hapla Vaclav" <[email protected]> writes:
On MacOS, maybe you also have lots of firewall popups appearing/disappearing when running tests like Do you want the application "ex29" to accept incoming network connections?
Is there a way to express that the application does not need (should not accept) incoming connections? Normalizing sudo during build/testing seems really bad.
2173
Age (days ago)
2173
Last active (days ago)
0 comments
1 participants
participants (1)
Jed Brown
