Re: [petsc-dev] Fwd: no petsc on Edison
Mark: Try '-matmatmult_via scalable' first. If this works, should we set it as default? Hong
On Thu, Feb 2, 2017 at 10:53 AM, Satish Balay <[email protected]> wrote:
[3404]PETSC ERROR: Memory allocated 0 Memory used by process 2537885696 [3404]PETSC ERROR: Memory requested 657532760
So the process is currently using 2.5GB - and then made a malloc request for 650MB - and this failed?
Yep, large but not garbage.
How many 'tasks-per-node' are you using? Perhaps you need to reduce this number?
Treb has run this job before and I think this code has been touched recently ... I suggested that Treb try -matmatmult_via scalable
https://www.nersc.gov/users/computational-systems/edison/configuration/ 64GB/node <https://www.nersc.gov/users/computational-systems/edison/configuration/64GB/node> => 5.3GB/process for tasks-per-node=12 [and 2.6GB/node for tasks-per-node=24]
Satish
On Wed, 1 Feb 2017, Mark Adams wrote:
We are getting this error on Edison. This problem has run before. This is using maint from last week.
I recall there are low memory options for mpiptap. I don't think we are using them.
3404]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [3404]PETSC ERROR: Out of memory. This could be due to allocating [3404]PETSC ERROR: too large an object or bleeding by not properly [3404]PETSC ERROR: destroying unneeded objects. [3404]PETSC ERROR: Memory allocated 0 Memory used by process 2537885696 <(253)%20788-5696>
[3404]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info. [3404]PETSC ERROR: Memory requested 657532760 [3404]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d ocumentation/faq.html for trouble shooting. [3404]PETSC ERROR: Petsc Release Version 3.7.5, unknown [3404]PETSC ERROR: /tmp/targetExec on a arch-xc30-opt64-intel named nid00713 by u6338 Wed Feb 1 16:15:09 2017 [3404]PETSC ERROR: Configure options --COPTFLAGS="-fast -no-ipo" --CXXOPTFLAGS="-fast -no-ipo" --FOPTFLAGS="-fast -no-ipo" --download-parmetis --download-metis --download-hypre --with-ssl=0 --with-cc=cc --with-clib-autodetect=0 --with-cxx=CC --with-cxxlib-autodetect=0 --with-debugging=0 --with-fc=ftn --with-fortranlib-autodetect=0 --with-shared-libraries=0 --with-x=0 --with-mpiexec=srun LIBS=-lstdc++ --with-64-bit-indices --prefix=/global/homes/m/madams/petsc_install/petsc-xc30-opt64-intel PETSC_ARCH=arch-xc30-opt64-intel PETSC_DIR=/global/homes/m/mada ms/petsc_install/petsc [3404]PETSC ERROR: #1 MatMatMultNumeric_SeqAIJ_SeqAIJ() line 187 in /global/u2/m/madams/petsc_install/petsc/src/mat/impls/aij/ seq/matmatmult.c [3404]PETSC ERROR: #2 MatMatMultNumeric_SeqAIJ_SeqAIJ() line 187 in /global/u2/m/madams/petsc_install/petsc/src/mat/impls/aij/ seq/matmatmult.c [3404]PETSC ERROR: #3 MatPtAPNumeric_MPIAIJ_MPIAIJ() line 557 in /global/u2/m/madams/petsc_install/petsc/src/mat/impls/aij/mpi/mpiptap.c [3404]PETSC ERROR: #4 MatPtAP_MPIAIJ_MPIAIJ() line 110 in /global/u2/m/madams/petsc_install/petsc/src/mat/impls/aij/mpi/mpiptap.c [3404]PETSC ERROR: #5 MatPtAP() line 9150 in /global/u2/m/madams/petsc_inst all/petsc/src/mat/interface/matrix.c [3404]PETSC ERROR: #6 PCGAMGCreateLevel_GAMG() line 88 in /global/u2/m/madams/petsc_install/petsc/src/ksp/pc/impls/gamg/gamg.c [3404]PETSC ERROR: #7 PCSetUp_GAMG() line 611 in /global/u2/m/madams/petsc_install/petsc/src/ksp/pc/impls/gamg/gamg.c [3404]PETSC ERROR: #8 PCSetUp() line 968 in /global/u2/m/madams/petsc_inst all/petsc/src/ksp/pc/interface/precon.c [3404]PETSC ERROR: #9 KSPSetUp() line 390 in /global/u2/m/madams/petsc_inst all/petsc/src/ksp/ksp/interface/itfunc.c [3404]PETSC ERROR: #10 KSPSolve() line 599 in /global/u2/m/madams/petsc_inst all/petsc/src/ksp/ksp/interface/itfunc.c
[3406]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [3406]PETSC ERROR: Out of memory. This could be due to allocating [3406]PETSC ERROR: too large an object or bleeding by not properly [3406]PETSC ERROR: destroying unneeded objects. [3406]PETSC ERROR: Memory allocated 0 Memory used by process 2603798528 <(260)%20379-8528> <(260)%20379-8528> [3406]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info. [3406]PETSC ERROR: Memory requested 657532760 [3406]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d ocumentation/faq.html for trouble shooting. [3406]PETSC ERROR: Petsc Release Version 3.7.5, unknown [3406]PETSC ERROR: /tmp/targetExec on a arch-xc30-opt64-intel named nid00713 by u6338 Wed Feb 1 16:15:09 2017 [3406]PETSC ERROR: Configure options --COPTFLAGS="-fast -no-ipo" --CXXOPTFLAGS="-fast -no-ipo" --FOPTFLAGS="-fast -no-ipo" --download-parmetis --download-metis --download-hypre --with-ssl=0 --with-cc=cc --with-clib-autodetect=0 --with-cxx=CC --with-cxxlib-autodetect=0 --with-debugging=0 --with-fc=ftn --with-fortranlib-autodetect=0 --with-shared-libraries=0 --with-x=0 --with-mpiexec=srun LIBS=-lstdc++ --with-64-bit-indices --prefix=/global/homes/m/madams/petsc_install/petsc-xc30-opt64-intel PETSC_ARCH=arch-xc30-opt64-intel PETSC_DIR=/global/homes/m/madams/petsc_[7940]PETSC ERROR: -
participants (1)
Hong
