Re: [petsc-dev] pets error Segmentation Violation
No idea. You need to do what it says and run with valgrind or in a debugger. From the crash message it looks like it is crashing in your main program. Barry
On Jul 1, 2016, at 1:26 PM, 张江 <[email protected]> wrote:
I am trying to read a large data (11.7GB) with libmesh (integrated with PETSc) and use it for my application. The program runs well when using just one process. But in parallel (mpirun -n 4), some errors came out:
[0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors [0]PETSC ERROR: likely location of problem given in stack below [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------ [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available, [0]PETSC ERROR: INSTEAD the line number of the start of the function [0]PETSC ERROR: is given. [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Signal received [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Release Version 3.7.2, Jun, 05, 2016 [0]PETSC ERROR: ./ptracer on a arch-linux2-c-debug named compute001 by jiangzhang Fri Jul 1 10:07:07 2016 [0]PETSC ERROR: Configure options --prefix=/nfs/proj-tpeterka/jiang/opt/petsc-3.7.2 --download-fblaslapack --with-mpi-dir=/nfs/proj-tpeterka/jiang/libraries/mpich-3.2 [0]PETSC ERROR: #1 User provided function() line 0 in unknown file application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
Anybody know the possible causes?
participants (1)
Barry Smith
