Re: [petsc-dev] technical C question
On Thursday, April 7, 2016, Matthew Knepley <[email protected]> wrote:
On Thu, Apr 7, 2016 at 7:15 PM, Barry Smith <[email protected] <javascript:_e(%7B%7D,'cvml','[email protected]');>> wrote:
This works.
unsigned int joe = index%PETSC_BITS_PER_BYTE; if (joe > 7) joe = 7; return (BT_idx = index/PETSC_BITS_PER_BYTE, BT_c = array[BT_idx], BT_mask = (char)(1 << joe),
I think it is because clang is not smart enough to know that (index%PETSC_BITS_PER_BYTE) is always between 0 and 7.
Hence it thinks that you might be doing something like 1 << 9 which is as I understand it undefined http://stackoverflow.com/questions/21909412/why-would-the-outcome-of-this-sh...
So do we pander to the clang analyzer or just leave the warning? I vote to leave the warning and not change the code.
I believe Bill also encouraged us toward clean code rather than 0 warnings. I like this as well.
Some compilers allow you suppress warnings, potentially at file granularity via pragmas...
Matt
Barry
On Apr 7, 2016, at 5:56 PM, Jed Brown <[email protected] <javascript:_e(%7B%7D,'cvml','[email protected]');>> wrote:
Satish Balay <[email protected] <javascript:_e(%7B%7D,'cvml','[email protected]');>> writes:
On Thu, 7 Apr 2016, Jed Brown wrote:
Barry Smith <[email protected] <javascript:_e(%7B%7D,'cvml','[email protected]');>> writes:
Should we caste to an unsigned PetscInt first then?
It should be unsigned, yes. Does that fix the warning?
Nope..
Commenting out the following line - or changing the argument thus is making a difference.
diff --git a/src/mat/impls/baij/seq/baijfact.c b/src/mat/impls/baij/seq/baijfact.c index fea37cb..e2c210c 100644 --- a/src/mat/impls/baij/seq/baijfact.c +++ b/src/mat/impls/baij/seq/baijfact.c @@ -1081,7 +1081,7 @@ PetscErrorCode MatICCFactorSymbolic_SeqBAIJ(Mat fact,Mat A,IS perm,const MatFact ncols_upper++; } } - ierr = PetscIncompleteLLAdd(ncols_upper,cols,levels,cols_lvl,am,nlnk,lnk,lnk_lvl,lnkbt);CHKERRQ(ierr); + ierr = PetscIncompleteLLAdd(ncols,cols,levels,cols_lvl,am,nlnk,lnk,lnk_lvl,lnkbt);CHKERRQ(ierr);
That looks like it changes the semantics.
In any case, that file wasn't even mentioned in the message that Barry shared. If it is indeed the same issue, then it would appear that the static analyzer has determined that it is possible for index to be negative.
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
Jeff Hammond
