Re: [petsc-dev] invocation of nvcc
But I can get rid of that with: cc -E -mp-gpu I expect that is what they will say. On Thu, Nov 4, 2021 at 1:40 PM Satish Balay <[email protected]> wrote:
I think we went through this issue before.
nvc is the 'c' compiler. And for some reason its giving 'cuda' warnings.
I think you might have switched progenv last time [and avoided this compiler]
You can try using this compiler manually - on simple code - and then seek help from the admins on how to avoid these warnings..
Satish
- create test.c with:
#include <stdlib.h>
compile (or preporcess):
cc -E test.c
- You should get:
stderr: nvc-Warning-The -gpu option has no effect unless a language-specific option to enable GPU code generation is used (e.g.: -acc, -mp=gpu, -stdpar, -cuda)
Now provide this info to the machine admins [or nvidia folk] - and ask how to get rid of this message.
Satish
On Thu, 4 Nov 2021, Mark Adams wrote:
Correction it is nvc:
And I add -mp=gpu to CUDAFLAGS
Does anyone know if PETSc calls nvcc and hence can add flags to the invocation? nvcc wants a flag like -mp=gpu but I don't know if we do
that
or a compiler wrapper in the environment.
$ ./configure --help |grep CUDA <snip> --CUDAC=<prog> Specify the CUDA compiler --CUDAFLAGS=<string> Specify the CUDA compiler options <snip>
Satish
participants (1)
Mark Adams
