Re: [petsc-dev] error reading binary file
Okay, every matrix type except MPIAIJ respects -matload_block_size. Can you fix that? Can you fix that? On Tue, Jun 12, 2012 at 4:52 PM, Mark F. Adams <[email protected]>wrote:
Mine works in serial but not in parallel.
It looks like vecs are created in MatLoad via MatMPIAIJSetPreallocation_MPIAIJ and they are not split wrt blocks. here is the stack trace again:
[0]PETSC ERROR: PetscSplitOwnership() line 93 in /Users/markadams/Codes/petsc-dev/src/sys/utils/psplit.c [0]PETSC ERROR: PetscLayoutSetUp() line 147 in /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pmap.c [0]PETSC ERROR: MatMPIAIJSetPreallocation_MPIAIJ() line 3194 in /Users/markadams/Codes/petsc-dev/src/mat/impls/aij/mpi/mpiaij.c [0]PETSC ERROR: MatMPIAIJSetPreallocation() line 3928 in /Users/markadams/Codes/petsc-dev/src/mat/impls/aij/mpi/mpiaij.c [0]PETSC ERROR: MatLoad_MPIAIJ() line 3442 in /Users/markadams/Codes/petsc-dev/src/mat/impls/aij/mpi/mpiaij.c [0]PETSC ERROR: MatLoad() line 881 in /Users/markadams/Codes/petsc-dev/src/mat/interface/matrix.c [0]PETSC ERROR: main() line 109 in src/ksp/ksp/examples/tutorials/ex10.c
On Jun 12, 2012, at 5:43 PM, Jed Brown wrote:
On Tue, Jun 12, 2012 at 4:45 PM, Mark F. Adams <[email protected]>wrote:
Satish beat me to it. I still get the same error ... did you use -mat_block_size 3?
I will look in to further.
~/petsc/src/ksp/ksp/examples/tutorials$ ./ex10 -f0 binaryoutput-sym -ksp_monitor -pc_type gamg -mat_block_size 3 [0]PCSetData_AGG bs=3 MM=89373 0 KSP Residual norm 4.854898290598e-03 1 KSP Residual norm 1.748948970672e-03 2 KSP Residual norm 1.098105829371e-03 3 KSP Residual norm 7.267836867590e-04 4 KSP Residual norm 4.752091560022e-04 5 KSP Residual norm 3.152074302240e-04 6 KSP Residual norm 1.998139269819e-04 7 KSP Residual norm 1.142295077940e-04 8 KSP Residual norm 6.107885553654e-05 9 KSP Residual norm 2.903395117932e-05 10 KSP Residual norm 1.748667302607e-05 11 KSP Residual norm 9.864255584167e-06 12 KSP Residual norm 5.077178570024e-06 13 KSP Residual norm 2.996102603244e-06 14 KSP Residual norm 2.293954251541e-06 15 KSP Residual norm 1.977076000505e-06 16 KSP Residual norm 1.729762967197e-06 17 KSP Residual norm 1.422352992308e-06 18 KSP Residual norm 1.063366577331e-06 19 KSP Residual norm 7.479518697501e-07 20 KSP Residual norm 4.861597752713e-07 21 KSP Residual norm 2.996075502312e-07 22 KSP Residual norm 1.962056634115e-07 23 KSP Residual norm 1.216036063867e-07 24 KSP Residual norm 8.556036439634e-08 25 KSP Residual norm 5.911194128322e-08 26 KSP Residual norm 3.784597093891e-08 Number of iterations = 26 Residual norm 7.51457e-10
participants (1)
Jed Brown
