Re: [petsc-dev] vector inner products
"Oxberry, Geoffrey Malcolm" <[email protected]> writes:
Agreed; we find the Hilbert space inner product improves the convergence a great deal when doing mesh refinement studies with quasi-Newton methods in a discretize-then-optimize approach.
The best example I can think of to argue against “hiding” the inner product inside of a DM
I don't think of it as hiding, just associating. Making a link from a Vec to a Mat violates the usual dependency direction. The Vec can unwittingly carry a reference to a Mat, but the normal Vec operations shouldn't be changed. We do create this sort of dependency inversion with DM that changes the way VecView behaves, for example. If DM isn't used, we would need to either create this extra association for the Mat (gross) or build the plumbing to inform every user of the Vec about the associated inner product. But I think every use that needs this special inner product is either already aware of the DM or logically should be aware of it.
instead of a Mat is that it could be used for automatically scaling the KKT systems solved in interior point methods (e.g., IPOPT); poorly-scaled problems arise sometimes in applications. Admittedly, these inner products tend to be diagonal, and thus there may be a better interface or abstraction for this functionality.
On Apr 12, 2018, at 13:28, Stefano Zampini <[email protected]> wrote:
The gradient norm is the one induced by the mass matrix of the DM associated with the control. In principle, TaoGradientNorm() can be replaced by DMCreateMassMatrix() + solve with the mass matrix.
For PDE constrained optimization, the “gradient norm” is crucial, since we consider optimization problems in Banach spaces. We should keep supporting it, maybe differently than as it is now, but keep it.
On Apr 12, 2018, at 11:21 PM, Jed Brown <[email protected]> wrote:
Are you thinking about this PR again?
https://bitbucket.org/petsc/petsc/pull-requests/506
There's an issue here that Krylov methods operate in the discrete inner product while some higher level operations are of interest in (approximations of) continuous inner products (or norms). The object in PETSc that endows continuous attributes (like a hierarchy, subdomains, fields) on discrete quantities is DM, so my first inclination is that any continuous interpretation of vectors, including inner products and norms, belongs in DM.
"Munson, Todd" <[email protected]> writes:
There is a bit of code in TAO that allows the user to change the norm to a matrix norm. This was introduced to get some mesh independent behavior in one example (tao/examples/tutorials/ex3.c). That norm, however, does not propagate down into the KSP methods and is only used for testing convergence of the nonlinear problem.
A few questions then: Is similar functionality needed in SNES? Are TAO and SNES even the right place for this functionality? Should it belong to the Vector class so that you can change the inner products and have all the KSP methods (hopefully) work correctly?
Note: that this discussion brings us to the brink of supporting an optimize-then-discretize approach. I am not convinced we should go down that rabbit hole.
Thanks, Todd.
participants (1)
Jed Brown
