Re: [petsc-dev] make -j not supported? Why???
Hi Tim, have you looked at make.log? It records the compiler commands there. Best regards, Karli On 02/25/2013 07:00 PM, Tim Tautges wrote:
Ok, I may be going off experience with 3.1 or getting my env variables messed up.
Better error message for the make -j thing is definitely a plus.
The next problem: I'm trying to see the actual compile line used to build my source file, because an include file isn't being found. I'm sure this is something I'm missing, but it would be easier to diagnose if I could see the compile command. Any clues?
Thanks.
- tim
On 02/25/2013 04:49 PM, Barry Smith wrote:
On Feb 25, 2013, at 2:30 PM, Tim Tautges <[email protected]> wrote:
but why its need to not support otherwise-standard make options? Similarly, PETSC_MAKE_STOP_ON_ERROR instead of make -k?
Hmm, with the cmake based build -k seems to work fine, it keeps on going compiling everything it can. Without the -k it stops when the first compile fails. So it is supporting the "otherwise-standard make options".
Yes, the legacy build which is only a fallback for when cmake fails, is funky. Are you using it? If so, let us know why and we'll try to improve the cmake version so that you don't need the legacy; even I don't use it any more.
Barry
- tim
-- =============================================================> "You will keep in perfect peace him whose mind is steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory ([email protected]) (telecommuting from UW-Madison) phone (gvoice): (608) 354-1459 1500 Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
participants (1)
Karl Rupp
