Re: [petsc-dev] please make myself and Satish admin on bitbucket.org/petsc
Trying out bitbucket - noticed one more thing. premise: We need multiple repos and multiple admins This looks difficult to implement [without admins sharing 'petsc' passwd - and doing everything as the owner - which sean/barray are trying out now]. Single repo - multiple admins is fine. multiple repos with a single 'owner/admin' is fine. With multiple repos we want reposGroupA - access-control-list-A reposGroupB - access-control-list-B [do this either in 1 account or 2 accounts - doesn't matter] To have a common access control list for a group of repos - 'user group' appears to be the thing to use [as we have to set access-list for each repo separately]. However this is not easy to admin: - user 'petsc' can create a group [petsc:groupA] - admin 'balay' can't modify this group [if he need to add another person] - admin 'balay can't look at the contents of [petsc:groupA] - to see who is in it and who is not. - however amdin 'balay' can create a new group [balay:groupB] - and add this to the access control list So we can set the accesscontrol list to repos petsc/petsc, petsc/buildsystem to be the following - but one will not know [without e-mail commuication] the complete list of folks in these groups. petsc:groupA balay:groupB bsmith:groupC This might work - We can ignore duplicate users across groups and keep adding users in the the personal groups - when in doubt. But deleting users will be combersome. So project admintration [with multiple admins] is not as simple as it appeared before.. Satish On Fri, 10 Feb 2012, Satish Balay wrote:
On Fri, 10 Feb 2012, Sean Farley wrote:
With petsc.cs.iit.edu - yes I have to create a project manually and assemble the group and admin/s . But with bitbucket - you can create your own account [ala project] and assemble your own group - aswell as set admins.
minor modification:
with petsc.cs.iit.edu I create the project - and set the initial admin/s. They can login and set the group as needed.
But usually I'm also the admin as most folks didn't want to deal with the admin part - it was easier to just tell me what was needed. [its usually manually editing authorized keys file]
I'll concede that the gui admin for bitbucket is perhaps better. [instead of logging in shell - you log-into a website and use the gui].
One good aspect of bitbucket thats not on petsc.cs.iit.edu is: If a user exists in multiple projects - the keys are duplicated manually for each project account on petsc.cs.iit.edu. However bitbucket maintains a single copy and uses it across all projects.
Since the number of projects was relatively small - the lack of this functionality wasn't a big deal..
After this creation - on petsc.cs.iit.edu any user in the group can create repos without my intervention.
hg clone foobar ssh://[email protected]//hg/petsc/foobar
With bitbucket - only owner can create the new repo [not any member of a default group]. Don't know about admins..
wrt delete - petsc.cs.iit.edu admin for project petsc can ssh over and delete repos [via shell access]. Looks like with bitbucket - only owner can do the deletion of repo [not even admins]
participants (1)
Satish Balay
