Re: [petsc-dev] git repo branches housekeeping
On Sun, 8 Apr 2018, Satish Balay wrote:
For more housekeeping - look at the remaining local and remote branches and figure-out what to do. [perhaps some of them are intermediate branches during rebase - or abandoned features that should be deleted].
For reference - current list of remote branches Satish ---------- $ git branch -r |wc -l 265 $ git branch -r origin/BarryFSmith/readmemd-created-online-with-bitbucket-1506004176072 origin/HEAD -> origin/master origin/adams/zeroDSOR origin/balay/atpesc-tutorial-2014-bgq origin/balay/atpesc-tutorial-2015-bgq origin/balay/atpesc-tutorial-2016-bgq origin/balay/fix-ctable-hash-again/maint origin/balay/fix-cxx-cmplx-single origin/balay/fix-rebuild-xsdktrilinos origin/balay/fix-superlu_dist-reuse-factornumeric1-maint-backport origin/balay/fix-uninstall origin/balay/giturl-fixes origin/balay/k-fujitsu-f90-v3.6 origin/balay/test origin/balay/to-maint-switch-hdf5-build-to-cmake origin/balay/update-builder-test origin/balay/update-elemental-nov-2016 origin/barry-test origin/barry/clarify-dmplex-documentation origin/barry/feature-baij-blockdiagonal-scale origin/barry/feature-petscviewerformat-register origin/barry/fix-zoltan-library-list/maint origin/barry/improve-secant-linesearch origin/barry/oana/spectral-toy-updates origin/barry/pyjac origin/barry/refactor-vecview origin/barry/saws-profile origin/barry/spectral-poisson origin/barry/ssisc-spectral-adjoint origin/bueler/clean-ex9 origin/dalcinl/fix-xaij-spd origin/dalcinl/math-isclose origin/dalcinl/ts-snes origin/damalbel/dmnetwork_nest origin/damalbel/dmnetwork_nest_fieldsplit origin/debo/mat-taij origin/debo/ts-fix-ex31 origin/debo/ts-irk origin/denera/snes-reasonview-indent-fix origin/denera/tao-anderson-multisecant origin/denera/tao-bounded-newton origin/denera/tao-linesearch-redesign origin/denera/tao-lmvm-recycling-bounded-refactor origin/denera/tao-merge-pgd-into-bncg origin/denera/tao-separate-quadratic-solvers origin/dmay/ksp-cvgtest-normtype-fix origin/emil/add-fortran-ts-pre-post-stage-step/maint origin/emil/fix-ts-dae-rebased-v2 origin/emil/ts-steady-state-ex31 origin/haplav/feature-dmplex-distributed-hdf5-read origin/hongzh/change-memkind-default origin/hongzh/remove-manual-unrolling origin/hongzh/swe origin/hongzh/symplectic-integrator origin/hongzh/timing_issue origin/hongzh/ts-matshell-example origin/hongzh/vectorize-inner-products origin/hzhang/add-matcompress origin/hzhang/dmnetwork-couple origin/hzhang/fix-mpi3_unusedvar origin/hzhang/fix-ptaptest origin/hzhang/ksp-fminres origin/hzhang/ksp-minresqlp origin/hzhang/vec_node/master origin/hzhang/vec_node/master-rebased origin/irving/fe-scalars origin/irving/snes-ex12-cleanup origin/jczhang/feature-vecscatter-mpi3shmem origin/jczhang/optimize-on-node-matrix origin/jczhang/optimize-vecscatter-multi-copy origin/jed/assembly-perf origin/jed/cray-externc origin/jed/defined-nocpp origin/jed/doc-xsetdm origin/jed/elbueler-snes-ex5-fixes origin/jed/feature-dmda-section origin/jed/feature-sf-local origin/jed/fix-mat-convert-basic-bs origin/jed/ksp-plugin origin/jed/make-lib-ordering origin/jed/mat-eigenvalue-cache origin/jed/mat-hash origin/jed/mat-kaij origin/jed/mat-taij origin/jed/matbaij-loop origin/jed/matzerorowscolumnslocal-null/maint origin/jed/mpi-2 origin/jed/next-seaice origin/jed/sr-driver origin/jed/sr-driver4 origin/jed/tao-status-string origin/jed/tap origin/jed/testsrcs-refresh origin/jed/ts-ex11-union origin/jed/ts-heat-plex origin/jed/vecghostgetvalues origin/john-saws-webosocket-update origin/john/saws-webui-upgrade origin/karlrupp/feature-fast-matmatmult origin/karlrupp/feature-optimize-opencl-petscfe origin/karlrupp/feature-pipelined-cg-viennacl origin/karlrupp/feature-viennacl-cuda origin/karlrupp/feature-viennacl-openmp origin/karlrupp/fix-viennacl-veccopy origin/karpeev/fix-pc-fieldsplit-reset origin/karpeev/mat-convert-nest-aij-test origin/karpeev/mat-reset origin/klaij/fieldsplit-simple-ex70 origin/knepley/feature-configure-kcomputer origin/knepley/feature-da-repartition origin/knepley/feature-error-logging origin/knepley/feature-fe-nonaffine origin/knepley/feature-optcontrol-mg origin/knepley/feature-pc-patch origin/knepley/feature-plex-example-nonconforming origin/knepley/feature-plex-functionals origin/knepley/feature-plex-l2-projection origin/knepley/feature-plex-nasm origin/knepley/feature-plex-parallel-submesh origin/knepley/feature-plex-snesvi-example origin/knepley/feature-snes-ex13-spectral origin/knepley/feature-snes-rewrite origin/knepley/feature-spectral-solutions origin/knepley/fix-dm-gmg origin/knepley/fix-ex62-tests origin/knepley/fix-fe-bd-integral origin/knepley/fix-fe-vector-spaces origin/knepley/fix-plex-hdf5-periodic origin/knepley/fix-plex-pointfunc-dim origin/knepley/fix-quadrature-order origin/knepley/fix-snes-ex69 origin/knepley/ibamr origin/knepley/pylith origin/madams/ex56params origin/madams/sor-residual origin/madams/sr-driver origin/madams/sr-driver2 origin/madams/sr-driver4 origin/madams/sr1 origin/maint origin/maint-3.2 origin/maint-3.3 origin/maint-3.4 origin/maint-3.5 origin/maint-3.6 origin/maint-3.7 origin/maint-3.8 origin/maint-tao-2.2 origin/mark/aij-overlap origin/mark/dm-bs-bug origin/mark/dmplex-generalize-periodicity origin/mark/ex48-jacobian origin/mark/feature-picell origin/mark/feature-plex-l2-projection origin/mark/fix-mat2 origin/mark/mat-fix-scale origin/mark/plex-tuts origin/mark/ts-ex11-mhd origin/master origin/master-tao origin/mlange/feature-plex-case origin/mlange/feature-plex-create-parallel origin/mlange/feature-plex-triangle origin/mlange/fix-adjacency-performance origin/mlange/fix-plex-cas-tests origin/mlange/fix-plex-hex-mesh origin/mlange/plex-create-parallel origin/mlange/plex-distributed-overlap origin/mlange/plex-hybrid-hdf5 origin/mlange/plex-redistribute origin/mlange/plex-sfc-reordering origin/mlange/plex-vertex-partitioning origin/mlange05/fix-gmsh-coordinates origin/next origin/next-apr-2016 origin/next-apr-2018 origin/next-jun-2015 origin/next-jun-2017 origin/next-may-2016 origin/next-nov-2017 origin/next-oct-2014 origin/next-sep-2017 origin/next-tmp origin/oana/spectral-toy origin/paulmullowney/aijcusp-ellpack-fix origin/pefarrell/dmshell-asm origin/pefarrell/nasm-fixes origin/peller/threadcomm origin/pr118/asmunder/DMDA-fortran-example/master origin/pr478/pfarrell/feature-dmplex-adapt origin/pr600/dmeiser/feature-examples-newmethod/master origin/prbrune/matcoloring-creategraph origin/prbrune/matcoloring-minpack origin/prbrune/matcoloring-misimprovement origin/prbrune/matcoloring-zoltan origin/prbrune/pcgamg-bootstrap origin/prbrune/pcgamg-classicalbootstrap origin/prbrune/pcgamg-cr origin/prbrune/sf-examplefix origin/prbrune/snes-ex19vtkoutput origin/prbrune/snes-fasadditive origin/prbrune/zoltanupdate origin/psanan/ksp-tutorial-ex60-fixes origin/psanan/ts-bz-examples origin/psanan/ts-multiscale origin/psanan/ts-rhs-partitions origin/psanan/ts-tests origin/psanan/vec-mtdot-fix origin/rmills/feature-aijmkl-optional-sparse-optimize origin/rmills/feature-gamg-use-matsell origin/rmills/fix-sell-matconvert origin/sarich/feature-submatrixfree origin/sarich/feature-tao-pounders-jacobian origin/sarich/fix-alquimia-static origin/sarich/mira origin/sarich/snesvi-subvec-options origin/sarich/tao-pounders-add-corr-test origin/scott/change-NO_RM-default origin/scott/documentation-walker origin/scott/test-harness-debugger origin/scott/test-harness-perform2 origin/scott/update-dm-dt-output origin/shri/FTRTDS-project origin/shri/dmnetwork-subnetworks origin/shri/ts-dae-semi-explicit origin/shri/ts-powergrid origin/stefano_zampini/feature-continuousadjoint origin/stefano_zampini/feature-matis-ptap-aij origin/stefano_zampini/feature-newmattype-elementlist origin/stefano_zampini/feature-pcgamg-useamat origin/stefano_zampini/new-elemental-interface origin/tisaac/buildsystem-feature-parallel origin/tisaac/buildsystem-feature-subst-link-flags origin/tisaac/config-fix-petsc-py origin/tisaac/darcy-inference origin/tisaac/dm-project-function-label origin/tisaac/dt-feature-vectur-quadrature origin/tisaac/dual-space-get-traces origin/tisaac/feature-dmfield origin/tisaac/feature-dmfield-orig origin/tisaac/feature-fe-integrate-nonaffine origin/tisaac/feature-gamg-compose-graph origin/tisaac/feature-picell origin/tisaac/feature-plex-example-nonconforming origin/tisaac/feature-seqaij-get-submat-row-unordered origin/tisaac/feature-seqaij-submat-col-unsorted origin/tisaac/feature-test-maxiter-filter origin/tisaac/fix-gamg-set-coordinates origin/tisaac/fix-height-ds origin/tisaac/gamg-more-info origin/tisaac/knepley/feature-composable-callbacks origin/tisaac/ksp-fix-cheby-pc-handling origin/tisaac/master-merge-mark-snesex56 origin/tisaac/moab-update origin/tisaac/pc-pbjacobi-vec-get-array-read origin/tisaac/petsc-next-upstream origin/tisaac/plex-descriptive-debug origin/tisaac/plex-feature-vec-get-star origin/tisaac/plex-fv-without-ghosts origin/tisaac/update-p4est origin/tisaac/warn-next-upstream origin/tmunson/tao-feature-hessian-lagrangian origin/tmunson/tao-fix-leastsquares-tests origin/tmunson/tao-upgrade-tron origin/vi/snes-newtonaugas
participants (1)
Satish Balay
