Re: [petsc-dev] Error with --download-strumpack
I have this change at: https://bitbucket.org/petsc/petsc/pull-requests/945/strumpack-update-to-vers... Satish On Tue, 24 Apr 2018, Satish Balay wrote:
If upgrading petsc to strumpack-2.2.0 - you can do:
diff --git a/config/BuildSystem/config/packages/strumpack.py b/config/BuildSystem/config/packages/strumpack.py index e3d32666f0..62054b4fb5 100644 --- a/config/BuildSystem/config/packages/strumpack.py +++ b/config/BuildSystem/config/packages/strumpack.py @@ -4,8 +4,9 @@ import os class Configure(config.package.CMakePackage): def __init__(self, framework): config.package.CMakePackage.__init__(self, framework) - self.gitcommit = 'v2.1.0' - self.download = ['git://https://github.com/pghysels/STRUMPACK','http://portal.nersc.gov/project/sparse/strumpack/strumpack-2.1.0.tar.gz'] + self.gitcommit = 'v2.2.0' + self.download = ['git://https://github.com/pghysels/STRUMPACK','https://github.com/pghysels/STRUMPACK/archive/'+self.gitcommit+'.tar.gz'] + self.downloaddirnames = ['STRUMPACK','strumpack'] self.functions = ['STRUMPACK_init'] self.includes = ['StrumpackSparseSolver.h'] self.liblist = [['libstrumpack.a']]
Satish
On Tue, 24 Apr 2018, Junchao Zhang wrote:
Great, thanks.
--Junchao Zhang
On Tue, Apr 24, 2018 at 11:54 AM, Balay, Satish <[email protected]> wrote:
Ok - for https://github.com/pghysels/STRUMPACK/archive/v2.2.0.tar.gz to work - you need:
diff --git a/config/BuildSystem/config/packages/strumpack.py b/config/BuildSystem/config/packages/strumpack.py index e3d32666f0..0edd9c19e0 100644 --- a/config/BuildSystem/config/packages/strumpack.py +++ b/config/BuildSystem/config/packages/strumpack.py @@ -6,6 +6,7 @@ class Configure(config.package.CMakePackage): config.package.CMakePackage.__init__(self, framework) self.gitcommit = 'v2.1.0' self.download = ['git://https://github.com/pghysels/STRUMPACK ','http://portal.nersc.gov/project/sparse/strumpack/strumpack-2.1.0.tar.gz '] + self.downloaddirnames = ['STRUMPACK','strumpack'] self.functions = ['STRUMPACK_init'] self.includes = ['StrumpackSparseSolver.h'] self.liblist = [['libstrumpack.a']]
Are you updating petsc-master to use v2.2.0 of strumpack?
Satish
You can use:
--download-strumpack=1 --download-strumpack-commit=v2.2.0
Currently the tarball URL used is http://portal.nersc.gov/project/sparse/strumpack/strumpack-2.1.0.tar.gz - and it uses the notation:
strumpack-2.1.0/
But https://github.com/pghysels/STRUMPACK/archive/v2.2.0.tar.gz would be using a different notation for 'dirname' - so configure can't find it.
Satish
Hi, Satish, This configure option --download-strumpack= https://github.com/pghysels/STRUMPACK/archive/v2.2.0.tar.gz does not work. It looks it is because the package uses upper case for its name.
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
for
details): ------------------------------------------------------------
Error during download/extract/detection of STRUMPACK:
Looking for STRUMPACK at git.strumpack, hg.strumpack or a directory starting with ['strumpack']
--Junchao Zhang
participants (1)
Satish Balay
