Re: [petsc-dev] Deflated Krylov solvers for PETSc
My personal experience is to use approximate eigenvectors to deflate conjugate gradient. In that regard, it is kinda like DGMRES, except that the iterative method is different. A lot of situations I have seen use eigenvectors, but just as what Vuik does, you never know when someone will propose something unconventional. Deflation being a general framework, it does not hurt (from a user's point of view) to add something to the library and let the user play. Jie ----- Original Message ----- From: "Matthew Knepley" <[email protected]> To: "For users of the development version of PETSc" <[email protected]> Sent: Wednesday, February 27, 2013 4:05:47 AM Subject: Re: [petsc-dev] Deflated Krylov solvers for PETSc I think the problem with that approach to deflation is preconditioning, unless you use injection as Vuik does. You can easily get this kind of projection by using MatShell. I tried Ronald Morgan's stuff when I was in grad school and it never made a bit of difference. Is there any situation where deflation is useful and cannot be phrased as our current MG? Matt
participants (1)
Jie Chen
