Re: [petsc-dev] [petsc-users] Multiple solves with PCMG fail
Barry Smith <[email protected]> writes:
Jed
There are some additional issues when the GMRES runs for zero iterations in computing eigenvalues for Cheby.
Hmm, what is right? Suggest that the user set -ksp_chebyshev_estimate_eigenvalues_random? Automatically fall back to that? Just picking arbitrary values doesn't seem right because the solver won't work right on the next solve.
static PetscErrorCode KSPChebyshevComputeExtremeEigenvalues_Private(KSP kspest,PetscReal *emin,PetscReal *emax) { PetscErrorCode ierr; PetscInt n,neig; PetscReal *re,*im,min,max;
PetscFunctionBegin; ierr = KSPGetIterationNumber(kspest,&n);CHKERRQ(ierr); ierr = PetscMalloc2(n,&re,n,&im);CHKERRQ(ierr); ierr = KSPComputeEigenvalues(kspest,n,re,im,&neig);CHKERRQ(ierr); min = PETSC_MAX_REAL; max = PETSC_MIN_REAL; for (n=0; n<neig; n++) { min = PetscMin(min,re[n]); max = PetscMax(max,re[n]); } ierr = PetscFree2(re,im);CHKERRQ(ierr); *emax = max; *emin = min;
* thread #1: tid = 0x3c16cf, 0x00000001041b6777 libpetsc.3.5.dylib`KSPSolve_Chebyshev(ksp=0x00007fb85197ac60) + 1495 at cheby.c:378, queue = 'com.apple.main-thread', stop reason = step over frame #0: 0x00000001041b6777 libpetsc.3.5.dylib`KSPSolve_Chebyshev(ksp=0x00007fb85197ac60) + 1495 at cheby.c:378 375 cheb->emin = cheb->tform[0]*min + cheb->tform[1]*max; 376 cheb->emax = cheb->tform[2]*min + cheb->tform[3]*max; 377 -> 378 cheb->estimate_current = PETSC_TRUE; 379 } 380 381 ksp->its = 0; (lldb) p cheb->emin (PetscReal) $11 = -1.7976931348623158E+307 (lldb) p cheb->emax (PetscReal) $12 = -Inf
This puts giberish into the eigenvalue estimates.
I am not sure how you want to handle this?
The zero right hand side zero, initial guess case is a great corner case for testing complicated solvers :-) I’d forgotten about it for many years
participants (1)
Jed Brown
