Re: [petsc-dev] petsc-dev on bitbucket
On Thu, 9 Feb 2012, Jed Brown wrote:
On Wed, Feb 8, 2012 at 11:31, Barry Smith <[email protected]> wrote:
Yes. If you can't have that then it is a pretty crappy system. Sort of like IBM 360 where you only had a root directory with a truckload of files in it. In excusable in 2012 (or even 1972).
Let's all stop using google and switch to 1998 Yahoo. It's so much easier to find things by navigating a hierarchy.
all these comparisions don't make anysense to me. perhaps I'm dense. Whats the 'bitbucket' whay to easily get the info represented by this single link: http://petsc.cs.iit.edu/petsc/ Here I can get 2 baisc type of info - the global info regarding all the repos - and some grouping info - where I can identyfy the related repo collections. Don't care if its implemented with hierirachal dirs or something else. Satish
participants (1)
Satish Balay
