Re: [petsc-dev] Mat assembly on GPUs ...
Mark Adams <[email protected]> writes:
On Sun, Mar 29, 2020 at 6:20 PM Jed Brown <[email protected]> wrote:
We are interested in assembling point-block diagonals for use in pbjacobi smoothing. This is much simpler than AIJ,
Would the coloring/DD algo on the outside be the same, just with a different assembly kernel?
In one mode, though we can also do analytic stuff on the inside to avoid coloring (in which case we produce a bunch of elements or block-diagonal blocks).
Or are you looking a fusing the element construction with assembly? That seems reasonable now that I think about it.
It's the same coloring, right?
And, do we have an appropriate coloring method now?
Are you asking for a GPU-native coloring? Does your nonzero pattern change frequently?
participants (1)
Jed Brown
