Re: [petsc-dev] Error on Fugaku
PETSc seems to be skipping the compiler that it should use: -- Check for working CXX compiler: /opt/FJSVxtclanga/tcsds-1.2.31/bin/mpiFCC - skipped I see -fopenmp was added. This might be wrong. I use -Kopenmp. --help says: -fopenmp The -fopenmp option specifies to enable Specification of OpenMP Appli- cation Program Interface. When the -fopenmp option is specified, -mt is set. The -fopenmp option is needed if an object program compiled with the -fopenmp option exists in the command line as input files. Any ideas? On Wed, Apr 14, 2021 at 5:17 PM Satish Balay <[email protected]> wrote:
The following is working for me on the compute node [its completed kokkos (core) build - and is now building kokkos-kernels
~/petsc.save/arch-arm/lib/petsc/conf/reconfigure-arch-arm.py --download-p4est --download-zlib --download-kokkos --download-kokkos-kernels --download-kokkos-commit=origin/develop --download-cmake= https://github.com/Kitware/CMake/releases/download/v3.20.1/cmake-3.20.1.tar....
-DKokkos_ENABLE_OPENMP=ON give me some issue - so I didn't try any of the additional options..
Satish
On Wed, 14 Apr 2021, Mark Adams wrote:
Satish, I get this error.
I wonder if this syntax is wrong:
'--download-kokkos-cmake-arguments=-DCMAKE_BUILD_TYPE=Release -DBUILD_TESTING=OFF -DKokkos_ENABLE_LIBDL=OFF -DKokkos_ENABLE_OPENMP=ON -DKokkos_ENABLE_SERIAL=ON -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON',
Configuring KOKKOS with cmake; this may
take
several minutes
Executing: /usr/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/home/ra010009/a04199/petsc/arch-arm
-DCMAKE_INSTALL_NAME_DIR:STRING="/home/ra010009/a04199/petsc/arch-arm/lib"
-DCMAKE_INSTALL_LIBDIR:STRING="lib" -DCMAKE_VERBOSE_MAKEFILE=1 -DCMAKE_BUILD_TYPE=Release -DCMAKE_C_COMPILER="mpifcc" -DMPI_C_COMPILER="mpifcc" -DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib -DCMAKE_C_FLAGS:STRING="-fPIC -Kfast,openmp -fopenmp" -DCMAKE_C_FLAGS_DEBUG:STRING="-fPIC -Kfast,openmp -fopenmp" -DCMAKE_C_FLAGS_RELEASE:STRING="-fPIC -Kfast,openmp -fopenmp" -DCMAKE_CXX_COMPILER="mpiFCC" -DMPI_CXX_COMPILER="mpiFCC" -DCMAKE_CXX_FLAGS:STRING="-Kfast,openmp -fopenmp -fPIC -fopenmp" -DCMAKE_CXX_FLAGS_DEBUG:STRING="-Kfast,openmp -fopenmp -fPIC -fopenmp" -DCMAKE_CXX_FLAGS_RELEASE:STRING="-Kfast,openmp -fopenmp -fPIC -fopenmp" -DCMAKE_Fortran_COMPILER="mpifrt" -DMPI_Fortran_COMPILER="mpifrt" -DCMAKE_Fortran_FLAGS:STRING="-fPIC -O -fopenmp" -DCMAKE_Fortran_FLAGS_DEBUG:STRING="-fPIC -O -fopenmp" -DCMAKE_Fortran_FLAGS_RELEASE:STRING="-fPIC -O -fopenmp" -DCMAKE_EXE_LINKER_FLAGS:STRING=" -fopenmp" -DBUILD_SHARED_LIBS:BOOL=ON -DUSE_XSDK_DEFAULTS=YES -DXSDK_ENABLE_DEBUG=NO -DCMAKE_INSTALL_RPATH_USE_LINK_PATH:BOOL=ON -DCMAKE_BUILD_WITH_INSTALL_RPATH:BOOL=ON -DKokkos_ENABLE_MPI=ON -DKokkos_ENABLE_SERIAL=ON -DKokkos_ENABLE_OPENMP=ON -DCMAKE_CXX_STANDARD="14" -DCMAKE_BUILD_TYPE=Release -DBUILD_TESTING=OFF -DKokkos_ENABLE_LIBDL=OFF -DKokkos_ENABLE_OPENMP=ON -DKokkos_ENABLE_SERIAL=ON -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON stdout: -- Setting default Kokkos CXX standard to 14 -- The CXX compiler identification is Fujitsu -- Check for working CXX compiler: /opt/FJSVxtclanga/tcsds-1.2.31/bin/mpiFCC -- Check for working CXX compiler: /opt/FJSVxtclanga/tcsds-1.2.31/bin/mpiFCC -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- The project name is: Kokkos -- Configuring incomplete, errors occurred! See also
"/vol0004/ra010009/a04199/petsc/arch-arm/externalpackages/git.kokkos/petsc-build/CMakeFiles/CMakeOutput.log".
Error configuring KOKKOS with cmake Could not execute "['/usr/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/home/ra010009/a04199/petsc/arch-arm
-DCMAKE_INSTALL_LIBDIR:STRING="lib" -DCMAKE_VERBOSE_MAKEFILE=1 -DCMAKE_BUILD_TYPE=Release -DCMAKE_C_COMPILER="mpifcc" -DMPI_C_COMPILER="mpifcc" -DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib -DCMAKE_C_FLAGS:STRING="-fPIC -Kfast,openmp -fopenmp" -DCMAKE_C_FLAGS_DEBUG:STRING="-fPIC -Kfast,openmp -fopenmp" -DCMAKE_C_FLAGS_RELEASE:STRING="-fPIC -Kfast,openmp -fopenmp" -DCMAKE_CXX_COMPILER="mpiFCC" -DMPI_CXX_COMPILER="mpiFCC" -DCMAKE_CXX_FLAGS:STRING="-Kfast,openmp -fopenmp -fPIC -fopenmp" -DCMAKE_CXX_FLAGS_DEBUG:STRING="-Kfast,openmp -fopenmp -fPIC -fopenmp" -DCMAKE_CXX_FLAGS_RELEASE:STRING="-Kfast,openmp -fopenmp -fPIC -fopenmp" -DCMAKE_Fortran_COMPILER="mpifrt" -DMPI_Fortran_COMPILER="mpifrt" -DCMAKE_Fortran_FLAGS:STRING="-fPIC -O -fopenmp" -DCMAKE_Fortran_FLAGS_DEBUG:STRING="-fPIC -O -fopenmp" -DCMAKE_Fortran_FLAGS_RELEASE:STRING="-fPIC -O -fopenmp" -DCMAKE_EXE_LINKER_FLAGS:STRING=" -fopenmp" -DBUILD_SHARED_LIBS:BOOL=ON -DUSE_XSDK_DEFAULTS=YES -DXSDK_ENABLE_DEBUG=NO -DCMAKE_INSTALL_RPATH_USE_LINK_PATH:BOOL=ON -DCMAKE_BUILD_WITH_INSTALL_RPATH:BOOL=ON -DKokkos_ENABLE_MPI=ON -DKokkos_ENABLE_SERIAL=ON -DKokkos_ENABLE_OPENMP=ON -DCMAKE_CXX_STANDARD="14" -DCMAKE_BUILD_TYPE=Release -DBUILD_TESTING=OFF -DKokkos_ENABLE_LIBDL=OFF -DKokkos_ENABLE_OPENMP=ON -DKokkos_ENABLE_SERIAL=ON -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON']": -- Setting default Kokkos CXX standard to 14 -- The CXX compiler identification is Fujitsu -- Check for working CXX compiler: /opt/FJSVxtclanga/tcsds-1.2.31/bin/mpiFCC -- Check for working CXX compiler: /opt/FJSVxtclanga/tcsds-1.2.31/bin/mpiFCC -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- The project name is: Kokkos -- Configuring incomplete, errors occurred! See also
"/vol0004/ra010009/a04199/petsc/arch-arm/externalpackages/git.kokkos/petsc-build/CMakeFiles/CMakeOutput.log".CMake
Error at cmake/kokkos_compiler_id.cmake:129 (STRING):
* STRING sub-command REPLACE requires at least four arguments.*Call Stack (most recent call first): cmake/kokkos_tribits.cmake:174 (INCLUDE) CMakeLists.txt:166 (KOKKOS_SETUP_BUILD_ENVIRONMENT)
On Wed, Apr 14, 2021 at 3:34 PM Satish Balay <[email protected]> wrote:
Additional kokkos cmake arguments can be passed in via --download-kokkos-cmake-arguments=string option.
Satish
Satish,
For the fujitsu compiler OMP is -Kopenmp.
Sarat (cc'ed) tells me that he built Kokkos with:
cmake -DCMAKE_BUILD_TYPE=Release \ -DCMAKE_INSTALL_PREFIX=${KOKKOS_SRC_DIR}/install \ -DBUILD_TESTING=OFF \ -DKokkos_ENABLE_LIBDL=OFF \ -DKokkos_ENABLE_OPENMP=ON \ -DKokkos_ENABLE_SERIAL=ON \ -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON \ ..
How might I make this happen in PETSc?
Thanks, Mark
I have this building now. Do you know anything about OpenMP? I can add --with-openmp That should get Kokkos to be made with OpenMP. Should PETSc deal with the compilers correctly?
Well it tries the following compiler options for openmp.
oflags = ["-fopenmp", # Gnu "-qsmp=omp",# IBM XL C/C++ "-h omp", # Cray. Must come after XL because XL interprets this option as meaning "-soname omp" "-mp", # Portland Group "-Qopenmp", # Intel windows "-openmp", # Intel "-xopenmp", # Sun "+Oopenmp", # HP "/openmp" # Microsoft Visual Studio ]
I don't know what the flag for fugaku compiler is.
Satish
Thanks, Mark
On Wed, Apr 14, 2021 at 1:45 PM Mark Adams <[email protected]> wrote:
Thanks, If you feel inspired you could try Kokkos :|| I am in a parking lot waiting for my daughter but can try this when I get home, Thanks again, Mark
On Wed, Apr 14, 2021 at 1:33 PM Satish Balay < [email protected]> wrote:
I think I allocated a single node - and did the build on it.
Now I'm getting an error - don't know what changed..
login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "rscgrp=eap-int" -L "elapse=1:00:00" --sparam "wait-time=600" [ERR.] PJM 0059 pjsub rscgrp=eap-int is disabled.
Ok - the following worked..
login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "elapse=1:00:00" --sparam "wait-time=600" [INFO] PJM 0000 pjsub Job 6301572 submitted. [INFO] PJM 0081 .connected. [INFO] PJM 0082 pjsub Interactive job 6301572 started. [a04201@j31-3110s petsc]$
Ok - trying this build now.
[a04201@j31-3110s petsc]$ cat ~/petsc.save/arch-arm/lib/petsc/conf/reconfigure-arch-arm.py #!/usr/bin/python3 if __name__ == '__main__': import sys import os sys.path.insert(0, os.path.abspath('config')) import configure configure_options = [ '--with-blaslapack-lib=-lfjlapack', '--with-debugging=0', 'CC=mpifcc', 'CXX=mpiFCC', 'FC=mpifrt', 'PETSC_ARCH=arch-arm', ] configure.petsc_configure(configure_options) [a04201@j31-3110s petsc]$ ~/petsc.save/arch-arm/lib/petsc/conf/reconfigure-arch-arm.py --download-p4est --download-zlib <snip> p4est: Includes: -I/vol0004/ra010009/a04201/petsc/arch-arm/include Library: -Wl,-rpath,/vol0004/ra010009/a04201/petsc/arch-arm/lib -L/vol0004/ra010009/a04201/petsc/arch-arm/lib -lp4est -lsc
Ok - this worked for me.
Satish
Do you recall what nodes you use to build on a "compute" node, to avoid cross compilation?
On Wed, Apr 14, 2021 at 12:08 PM Satish Balay < [email protected]> wrote:
looks like p4est cannot be cross-compiled.
Satish
I get this error with p4est on Fugaku. It is a Fortran error. Odd. Mark
participants (1)
Mark Adams
