Re: [petsc-dev] [EXTERNAL] Re: building on Fugaku
I settled on this: . /vol0004/apps/oss/spack/share/spack/setup-env.sh spack load [email protected]%[email protected] arch=linux-rhel8-a64fx spack load [email protected]%[email protected] arch=linux-rhel8-a64fx 'CC=mpicc', 'CXX=mpiCC', 'FC=mpif90', 'COPTFLAGS=-Ofast -march=armv8.2-a+sve -msve-vector-bits=512', 'CXXOPTFLAGS=-Ofast -march=armv8.2-a+sve -msve-vector-bits=512', Kokkos suggested this and I noticed that it helped: export OMP_PROC_BIND=spread export OMP_PLACES=threads I am getting great thread scaling but I seem to get no vectorization. I discussed this with Kokkos (Trott) today and he is not surprised. Auto vectorization is fragile. On Mon, Apr 19, 2021 at 8:26 PM Sreepathi, Sarat <[email protected]> wrote:
My turn: did you folks figure out tips for performant hybrid MPI+OMP core binding? I tried some from the documentation but that didn’t seem to help.
-Sarat.
*From:* Sreepathi, Sarat *Sent:* Friday, April 16, 2021 3:02 PM *To:* Mark Adams <[email protected]>; petsc-dev <[email protected]> *Cc:* Satish Balay <[email protected]> *Subject:* RE: [petsc-dev] [EXTERNAL] Re: building on Fugaku
It’s 48 cores but there are 4 NUMA domains (CMGs). So, you may want to experiment in hybrid mode (4x12 etc.) if possible.
-Sarat.
*From:* Mark Adams <[email protected]> *Sent:* Friday, April 16, 2021 2:10 PM *To:* petsc-dev <[email protected]> *Cc:* Satish Balay <[email protected]>; Sreepathi, Sarat <[email protected]> *Subject:* Re: [petsc-dev] [EXTERNAL] Re: building on Fugaku
Sarat, is there anything special that you do for Kokkos - OpenMP?
Just set OMP_NUM_THREADS=48 ?
Also, I am confused about the number of cores here. Is 48 or 64 per node/socket?
On Fri, Apr 16, 2021 at 2:03 PM Mark Adams <[email protected]> wrote:
Cool, I have it running too. Need to add Sarat's flags and test ex2.
On Fri, Apr 16, 2021 at 1:57 PM Satish Balay via petsc-dev < [email protected]> wrote:
Mark,
The following build works for me:
Satish
pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "elapse=1:00:00" --sparam "wait-time=1200"
. /vol0004/apps/oss/spack/share/spack/setup-env.sh spack load fujitsu-mpi%gcc spack load [email protected] arch=linux-rhel8-a64fx ./configure COPTFLAGS='-Ofast -march=armv8.2-a+sve -msve-vector-bits=512' CXXOPTFLAGS='-Ofast -march=armv8.2-a+sve -msve-vector-bits=512' FOPTFLAGS='-Ofast -march=armv8.2-a+sve -msve-vector-bits=512' --with-openmp=1 --download-p4est --download-zlib --download-kokkos --download-kokkos-kernels --download-kokkos-commit=origin/develop --download-kokkos-kernels-commit=origin/develop '--download-kokkos-cmake-arguments=-DBUILD_TESTING=OFF -DKokkos_ENABLE_LIBDL=OFF -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON' --download-cmake= https://github.com/Kitware/CMake/releases/download/v3.20.1/cmake-3.20.1.tar.... --download-fblaslapack=1 make PETSC_DIR=/vol0004/ra010009/a04201/petsc.z PETSC_ARCH=arch-linux-c-debug all
To test - redo job allocation using max-proc-per-node:
login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "elapse=1:00:00" --sparam "wait-time=1200" --mpi "max-proc-per-node=16"
[a04201@c31-3201c petsc.z]$ . /vol0004/apps/oss/spack/share/spack/setup-env.sh [a04201@c31-3201c petsc.z]$ spack load fujitsu-mpi%gcc [a04201@c31-3201c petsc.z]$ spack load [email protected] arch=linux-rhel8-a64fx [a04201@c31-3201c petsc.z]$ make check Running check examples to verify correct installation Using PETSC_DIR=/vol0004/ra010009/a04201/petsc.z and PETSC_ARCH=arch-linux-c-debug C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes C/C++ example src/snes/tutorials/ex3k run successfully with kokkos-kernels Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI process Completed test examples [a04201@c31-3201c petsc.z]$
participants (1)
Mark Adams
