lots o' dead code in BuildSystem
~/Src/petsc barry/remove-sidl $ Vulture config config/builder.py:605: Unused variable 'comparsion' config/builder.py:639: Unused function 'extractTests' config/builder.py:663: Unused attribute 'cmd' config/builder.py:684: Unused attribute 'ret' config/builder.py:684: Unused attribute 'store' config/builder.py:704: Unused function 'updateNode' config/builder.py:1093: Unused attribute 'memAlign' config/builder.py:1250: Unused attribute 'operationFailed' config/builder.py:1290: Unused function 'compileCUDA' config/builder.py:1293: Unused function 'compileCxx' config/builder.py:1296: Unused function 'compileFortran' config/builder.py:1342: Unused function 'compileCParallel' config/builder.py:1345: Unused function 'compileCxxParallel' config/builder.py:1348: Unused function 'compileFortranParallel' config/builder.py:1374: Unused function 'expandArchive' config/builder.py:1677: Unused function 'checkTestOutput' config/builder.py:1680: Unused function 'checkTestOutputSolver' config/builder.py:1777: Unused function 'buildEtags' config/BuildSystem/args.py:69: Unused attribute '_setCommandLine' config/BuildSystem/build/buildGraph.py:71: Unused function 'removeSubgraph' config/BuildSystem/build/compile/C.py:6: Unused attribute 'usingC' config/BuildSystem/build/compile/Cxx.py:6: Unused attribute 'usingCxx' config/BuildSystem/build/compile/F90.py:6: Unused attribute 'usingF90' config/BuildSystem/build/fileset.py:181: Unused class 'RootedExtensionFileSet' config/BuildSystem/build/fileState.py:61: Unused class 'GenericTag' config/BuildSystem/build/fileState.py:106: Unused class 'Update' config/BuildSystem/build/framework.py:27: Unused attribute 'directories' config/BuildSystem/build/framework.py:78: Unused function 'makeSourceDBPathsAbsolute' config/BuildSystem/build/framework.py:87: Unused function 'makeSourceDBPathsRelative' config/BuildSystem/build/framework.py:103: Unused variable 'newTmp' config/BuildSystem/build/framework.py:177: Unused function 't_activate' config/BuildSystem/build/framework.py:184: Unused function 't_deactivate' config/BuildSystem/build/framework.py:195: Unused function 't_configure' config/BuildSystem/build/framework.py:259: Unused function 't_compile' config/BuildSystem/build/framework.py:264: Unused function 't_compilePrograms' config/BuildSystem/build/framework.py:271: Unused function 't_install' config/BuildSystem/build/framework.py:290: Unused function 't_uninstall' config/BuildSystem/build/framework.py:306: Unused function 't_citool' config/BuildSystem/build/framework.py:312: Unused function 't_push' config/BuildSystem/build/framework.py:321: Unused function 't_pull' config/BuildSystem/build/framework.py:331: Unused function 't_makeStamp' config/BuildSystem/build/framework.py:339: Unused function 't_default' config/BuildSystem/build/framework.py:343: Unused function 't_printTargets' config/BuildSystem/build/framework.py:357: Unused function 't_purge' config/BuildSystem/build/framework.py:374: Unused function 't_update' config/BuildSystem/build/processor.py:341: Unused class 'DirectoryArchiver' config/BuildSystem/build/processor.py:386: Unused class 'Archiver' config/BuildSystem/build/processor.py:460: Unused class 'ImportSharedLinker' config/BuildSystem/build/processor.py:507: Unused class 'LibraryAdder' config/BuildSystem/build/transform.py:41: Unused class 'Filter' config/BuildSystem/build/transform.py:59: Unused class 'Remover' config/BuildSystem/build/transform.py:80: Unused class 'Consolidator' config/BuildSystem/config/base.py:189: Unused function 'addArgumentSubstitution' config/BuildSystem/config/base.py:279: Unused function 'getExecutables' config/BuildSystem/config/base.py:658: Unused function 'splitIncludes' config/BuildSystem/config/compile/processor.py:70: Unused function 'pushRequiredFlags' config/BuildSystem/config/compile/processor.py:73: Unused function 'popRequiredFlags' config/BuildSystem/config/compilers.py:21: Unused attribute 'cRestrict' config/BuildSystem/config/compilers.py:22: Unused attribute 'cxxRestrict' config/BuildSystem/config/framework.py:366: Unused function 'updatePackageDependencies' config/BuildSystem/config/framework.py:465: Unused function 'addSubstitutionFile' config/BuildSystem/config/framework.py:938: Unused attribute '_configured' config/BuildSystem/config/package.py:61: Unused attribute 'double' config/BuildSystem/config/package.py:62: Unused attribute 'complex' config/BuildSystem/config/package.py:63: Unused attribute 'requires32bitint' config/BuildSystem/config/package.py:94: Unused attribute 'openmpi' config/BuildSystem/config/package.py:542: Unused variable 'foundLibrary' config/BuildSystem/config/package.py:543: Unused variable 'foundHeader' config/BuildSystem/config/packages/cuda.py:24: Unused attribute 'ThrustVersionStr' config/BuildSystem/config/packages/cuda.py:25: Unused attribute 'CUSPVersionStr' config/BuildSystem/config/packages/MPI.py:46: Unused attribute 'shared' config/BuildSystem/config/packages/MPI.py:48: Unused attribute 'commf2c' config/BuildSystem/config/packages/MPI.py:49: Unused attribute 'commc2f' config/BuildSystem/config/packages/MPI.py:181: Unused attribute 'haveFinalized' config/BuildSystem/config/packages/MPI.py:184: Unused attribute 'haveInPlace' config/BuildSystem/config/packages/MPI.py:188: Unused attribute 'haveTypeCreateStruct' config/BuildSystem/config/packages/MPI.py:193: Unused attribute 'haveCommCreateErrhandler' config/BuildSystem/config/packages/MPI.py:198: Unused attribute 'haveCommSetErrhandler' config/BuildSystem/config/packages/MPI.py:410: Unused attribute 'havef90module' config/BuildSystem/config/packages/mpi4py.py:14: Unused attribute 'numpy' config/BuildSystem/config/packages/mpi4py.py:22: Unused variable 'pp' config/BuildSystem/config/packages/mpi4py.py:24: Unused variable 'apple' config/BuildSystem/config/packages/SuperLU_MT.py:12: Unused attribute 'worksonWindows' config/BuildSystem/config/packages/Triangle.py:28: Unused variable 'installmakeinc' config/BuildSystem/config/python.py:12: Unused attribute 'isShared' config/BuildSystem/config/regression/frameworkTest.py:10: Unused class 'FrameworkTest' config/BuildSystem/config/regression/frameworkTest.py:42: Unused function 'testEmptyConfigure' config/BuildSystem/config/regression/frameworkTest.py:47: Unused function 'testLogName' config/BuildSystem/config/regression/frameworkTest.py:54: Unused function 'testFullDefaultConfigure' config/BuildSystem/config/regression/shellTest.py:6: Unused class 'ShellTest' config/BuildSystem/config/regression/shellTest.py:14: Unused function 'testTimeout' config/BuildSystem/config/setCompilers.py:22: Unused attribute 'usedMPICompilers' config/BuildSystem/config/setCompilers.py:622: Unused attribute 'compilerVersionCUDA' config/BuildSystem/config/setCompilers.py:997: Unused attribute 'usePIC' config/BuildSystem/config/setCompilers.py:1020: Unused attribute 'isPIC' config/BuildSystem/config/setCompilers.py:1197: Unused attribute 'staticLinker' config/BuildSystem/config/setCompilers.py:1287: Unused function 'addLinkerFlag' config/BuildSystem/config/setCompilers.py:1373: Unused attribute 'staticLibrary' config/BuildSystem/config/setCompilers.py:1374: Unused attribute 'sharedLibrary' config/BuildSystem/config/setsBackport.py:454: Unused function 'union_update' config/BuildSystem/config/setsBackport.py:464: Unused function 'intersection_update' config/BuildSystem/config/setsBackport.py:541: Unused function 'discard' config/BuildSystem/config/setsOrdered.py:547: Unused function 'updateDuplicate' config/BuildSystem/config/setsOrdered.py:633: Unused class 'SetsTest' config/BuildSystem/config/setsOrdered.py:634: Unused function 'testOrdering' config/BuildSystem/config/setsOrdered.py:640: Unused function 'testUniqueness' config/BuildSystem/config/setsOrdered.py:646: Unused function 'testOrder' config/BuildSystem/config/sourceControl.py:31: Unused attribute 'gitversion' config/BuildSystem/config/sourceControl.py:42: Unused attribute 'hgversion' config/BuildSystem/config/sourceControl.py:51: Unused attribute 'cvxversion' config/BuildSystem/config/sourceControl.py:60: Unused attribute 'svnversion' config/BuildSystem/config/types.py:128: Unused function 'checkFortranStar' config/BuildSystem/maker.py:33: Unused function 'getMake' config/BuildSystem/maker.py:232: Unused class 'BasicMake' config/BuildSystem/nargs.py:5: Unused function 'getInteractive' config/BuildSystem/nargs.py:46: Unused function 'setTemporary' config/BuildSystem/nargs.py:144: Unused function 'getKey' config/BuildSystem/nargs.py:206: Unused class 'ArgFuzzyBool' config/BuildSystem/nargs.py:274: Unused class 'ArgReal' config/BuildSystem/nargs.py:390: Unused class 'ArgExecutable' config/BuildSystem/RDict.py:269: Unused function 'hasType' config/BuildSystem/RDict.py:541: Unused function 'handle' config/BuildSystem/retrieval.py:123: Unused function 'ftpRetrieve' config/BuildSystem/retrieval.py:127: Unused function 'httpRetrieve' config/BuildSystem/retrieval.py:131: Unused function 'fileRetrieve' config/BuildSystem/retrieval.py:135: Unused function 'svnRetrieve' config/BuildSystem/retrieval.py:147: Unused function 'bkUpdate' config/BuildSystem/retrieval.py:217: Unused function 'retrieve' config/BuildSystem/retrieval.py:239: Unused function 'removeRoot' config/BuildSystem/retrieval.py:261: Unused function 'bkfileRetrieve' config/BuildSystem/retrieval.py:266: Unused function 'sshRetrieve' config/BuildSystem/retrieval.py:271: Unused function 'oldRetrieve' config/BuildSystem/script.py:41: Unused attribute 'shell' config/BuildSystem/script.py:83: Unused attribute '_setup' config/BuildSystem/script.py:293: Unused attribute 'outputFiles' config/BuildSystem/script.py:414: Unused function 'setPreprocessorObject' config/BuildSystem/script.py:428: Unused function 'setCompilerObject' config/BuildSystem/script.py:444: Unused function 'setLinkerObject' config/BuildSystem/script.py:476: Unused function 'setDynamicLinkerObject' config/BuildSystem/sourceDatabase.py:185: Unused function 'clearSource' config/BuildSystem/sourceDatabase.py:194: Unused function 'getDependencies' config/BuildSystem/sourceDatabase.py:215: Unused function 'calculateDependencies' config/BuildSystem/sourceDatabase.py:281: Unused class 'DependencyAnalyzer' config/BuildSystem/urlMappingInstalled.py:14: Unused function 'setupUrlMapping' config/cmakeboot.py:22: Unused function 'quoteIfNeeded' config/cmakegen.py:64: Unused function 'unexpected' config/examples/arch-bgp-ibm-opt.py:63: Unused variable 'test_options' config/PETSc/Configure.py:58: Unused attribute 'atomics' config/PETSc/Configure.py:739: Unused variable 'langs' config/PETSc/FEM.py:877: Unused function 'createFaceQuadrature' config/PETSc/FEM.py:904: Unused attribute 'list' config/PETSc/FEM.py:907: Unused attribute 'type' config/PETSc/FEM.py:909: Unused attribute 'static' config/PETSc/FEM.py:910: Unused attribute 'initializer' config/PETSc/FEM.py:923: Unused attribute 'identifier' config/PETSc/FEM.py:924: Unused attribute 'replacementText' config/PETSc/FEM.py:1098: Unused function 'getReferenceTensor' config/PETSc/FEM.py:1357: Unused attribute 'typedef' config/PETSc/FEM.py:1386: Unused function 'getQuadratureSetup' config/PETSc/FEM.py:1394: Unused attribute 'branch' config/PETSc/FEM.py:1449: Unused function 'getIntegratorPoints' config/PETSc/FEM.py:1510: Unused attribute 'caseLabel' config/PETSc/FEM.py:1569: Unused function 'getIntegratorSetup' config/PETSc/FEM.py:1578: Unused function 'getSectionSetup' config/PETSc/FEM.py:1669: Unused function 'getElementIntegrals' config/PETSc/FEM.py:1696: Unused attribute 'parameters' config/PETSc/FEM.py:1758: Unused attribute 'comments' config/PETSc/FEM.py:1814: Unused attribute 'purpose' config/PETSc/FEM.py:1904: Unused function 'runTensorProduct' config/PETSc/utilities/arch.py:54: Unused attribute 'archBase' config/PETSc/utilities/cacheDetails.py:29: Unused attribute 'updated' config/PETSc/utilities/CHUD.py:39: Unused attribute 'haveCHUD' config/PETSc/utilities/libraryOptions.py:33: Unused attribute 'scalarTypes' config/PETSc/utilities/missing.py:86: Unused function 'configureMissingErrnos' config/PETSc/utilities/Regression.py:27: Unused attribute ‘elemental'
participants (1)
Barry Smith
