Re: [petsc-dev] PTScotch problem on Mac
The primary difference I can spot [as you say] is the older xcode you have. Eventhough it says the same version of flex - perhaps its buggy? Apple clang version 11.0.3 (clang-1103.0.32.59) vs Apple clang version 12.0.0 (clang-1200.0.32.2)
PATH=/PETSc3/cig/bin:/PETSc3/petsc/petsc-pylith/arch-pylith-debug/bin:/PETSc3/petsc/apple/bin:/Library/Frameworks/Python.framework/Versions/3.8/bin:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/texbin:/opt/X11/bin:/usr/local/git/bin:/Library/Frameworks/Python.framework/Versions/3.8/bin:/opt/local/bin:/opt/local/sbin:/usr/X11/bin:/usr/local/texlive/2019/bin/x86_64-darwin:/usr/local/cuda/bin:/usr/local/gmt/bin:/usr/local/bin:/usr/X11/bin:/usr/local/texlive/2019/bin/x86_64-darwin:/usr/local/cuda/bin:/usr/local/gmt/bin
BTW: Can you try a build with the following and see if it makes a difference? PATH=/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/opt/X11/bin ./configure PETSC_ARCH=arch-test --with-mpi-dir=/PETSc3/petsc/apple --download-c2html --download-ptscotch Satish On Tue, 23 Nov 2021, Matthew Knepley wrote:
Here it is.
Matt
On Tue, Nov 23, 2021 at 11:28 AM Satish Balay <[email protected]> wrote:
Well we don't have this issue on our (macos) CI boxes where both c2html and scotch build and run daily [in CI]
what 'flex' are you using? And why does it behave differently on your box?
main *$:/PETSc3/petsc/petsc-dev$ which flex /usr/bin/flex main *$:/PETSc3/petsc/petsc-dev$ flex --version flex 2.5.35 Apple(flex-32)
And what errors do you get?
Without the extra input define in PTScotch.py, I get the yylval symbol undefined and the lexer symbol. When I give that define as input, only the lexer symbol is undefined.
BTW: Can you send the log?
Satish
Perhaps CI is using older xcode (command line tools) - and you are
using
newer? Or something else?
Probably the other way around. I am on Catalina 10.15.6
Matt
Barry - do you have this issue on your machine?
balay@ypro ~ % which flex /usr/bin/flex balay@ypro ~ % /usr/bin/flex --version flex 2.5.35 Apple(flex-32) balay@ypro petsc % clang -v Apple clang version 12.0.0 (clang-1200.0.32.2) Target: x86_64-apple-darwin19.6.0 Thread model: posix InstalledDir: /Library/Developer/CommandLineTools/usr/bin balay@ypro ~ % balay@ypro petsc % ./configure --with-mpi-dir=$HOME/mpich-3.4.2 --download-c2html --download-ptscotch
<log attached>
Satish
This is the same flex problem as I had for c2html, but I was more determined tracking it down this time. The first problem is that we were not renaming in the parser,
main *$:/PETSc3/petsc/petsc-dev$ git diff diff --git a/config/BuildSystem/config/packages/PTScotch.py b/config/BuildSystem/config/packages/PTScotch.py index d1c277b6e9f..e046804c17f 100644 --- a/config/BuildSystem/config/packages/PTScotch.py +++ b/config/BuildSystem/config/packages/PTScotch.py @@ -70,7 +70,7 @@ class Configure(config.package.Package): if self.libraries.add('-lrt','timer_create'): ldflags += ' -lrt' self.cflags = self.cflags + ' -DCOMMON_RANDOM_FIXED_SEED' # do not use -DSCOTCH_PTHREAD because requires MPI built for threads. - self.cflags = self.cflags + ' -DSCOTCH_RENAME -Drestrict="'+self.compilers.cRestrict+'"' + self.cflags = self.cflags + ' -DSCOTCH_RENAME -DSCOTCH_RENAME_PARSER -Drestrict="'+self.compilers.cRestrict+'"' # this is needed on the Mac, because common2.c includes common.h which DOES NOT include mpi.h because # SCOTCH_PTSCOTCH is NOT defined above Mac does not know what clock_gettime() is! if self.setCompilers.isDarwin(self.log):
Second, they were not treating this case completely correctly:
(93454e8...):/PETSc3/petsc/petsc-dev/arch-master-debug/externalpackages/git.ptscotch/src/libscotch$
git diff HEAD~1 diff --git a/src/libscotch/parser_yy.h b/src/libscotch/parser_yy.h index 931315d..95b8160 100644 --- a/src/libscotch/parser_yy.h +++ b/src/libscotch/parser_yy.h @@ -62,6 +62,9 @@
#if ((defined SCOTCH_RENAME_PARSER) || (defined yylex)) /* If prefix renaming */ #define scotchyyparse stratParserParse2 /* Parser function name */ +#if !defined(yylex) +#define yylex scotchyylex +#endif #ifndef yylval #define yylval SCOTCH_NAME_MACRO3 (scotchyy, SCOTCH_NAME_SUFFIXC, lval) /* It should be Yacc/Bison's job to redefine it! */ #endif /* yylval */
How should we go about getting this fix in? Do you need to have our own branch of PTScotch?
Matt
participants (1)
Satish Balay
